f20b swap into 93 accord
hey so i got a few questions im in the middle of this swap and i ran into a couple problems
the driver side mount under the timing belt cover doesnt line up with the moung off my f22 would an h22 mount fit or is there any other mount that would line up?
the map sensor on the f20b is on the top of the throttle body should i use that and just splice the clip into my harness or just use the map sensor off my f20b that was in the control box on the firewall?
i was told to swap the guts from the obd2 f20b dizzy into the obd1 f22 dizzy because i need the internal coil has anyone done that and if so where do i start ?
vtecsk8r
Feb 21, 2014 07:58 AM
