Suspension & Brakes Theory, alignment, spring rates....
new to the camber and toe issue
Old Mar 21, 2010 | 08:38 AM
speedfreak44's Avatar
Default new to the camber and toe issue
vehicle= civic eg9
car has being lower about 2''
what do i need to now, camber kit?
im a bit confused as to how to set the camber, the car is a daily driver only, so do i set the camber at 0 degres, im so confused , because i read some issues as to the cant be set due to cornoring , under inflation etc...
please guide
Old Mar 21, 2010 | 10:40 AM
96hb's Avatar
Default Re: new to the camber and toe issue
You don't need a camber kit. Just go get an alignment and have them set the toe as close to 0 as possible. A little negative camber is good and it won't really wear out your tires any faster. A little tip is to have your tires flipped on the rims once they start showing some inner wear. I have 30k miles on my pos Kuhmos at the moment and am about to do that on my fronts. My rears still have tons of tread on them. I'm lowered about 3" and have never had a camber kit in my life.
Old Mar 21, 2010 | 01:08 PM
98civdx's Avatar
Master Detailer
im lowerd 3-3.5 inches with no camber kit and my tires are just starting to show camber wear, coming up on a year.
Old Mar 21, 2010 | 01:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
read the stickied thread at the top of the forum.
thanks guys... respected
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
Trumpster
Suspension & Brakes
Feb 2, 2005 08:14 PM
evowu
Jan 23, 2004 09:02 PM
distortedfuture
Dec 5, 2003 10:21 AM
seineil
Jul 30, 2002 11:26 PM
