B-series, G22, F22 questions
Old Mar 21, 2010 | 07:17 AM
ZCHondaCRX91's Avatar
Default B-series, G22, F22 questions
I wanted to know if the F22A block (like in the 90-93 accord) are the same as the F22B? I can't find a exact answer, will a H22 head swap be the same as on a F22B? Also I found a compression ratio calculator for D, K and B-series engines, but can't find one for H and F series engines, do you know any that I could use?
Another question is I got a b-series flywheel, but don't know which one it is, I know the Type R weights less and the rest are the same weight. My scale won't work on anything under 20 pounds, so is there a number or letter that would tell me what it is?
Thank you.
Also if I swap it into a 91 CRX, what wire harness do I need for OBD-1, is it just like anyother swap?
Old Mar 21, 2010 | 01:14 PM
ys1civicsi's Avatar
Default Re: B-series, G22, F22 questions
wow man you need to start doing some research. when you are a little more knowledgable come back
Old Mar 22, 2010 | 08:41 AM
I did research or else I wouldn't post on here. I never found a clear answer or not if the F22A is the exact same setup for a G22 VTEC swap as a F22B or F23. Everything else I got off of other forums, from people who actually helped.
Old Mar 22, 2010 | 12:13 PM
ys1civicsi's Avatar
First of all it is A G23 Swap start from there
TMX
May 9, 2014 05:29 AM
spcrxracer
13
Jan 29, 2011 08:27 PM
bigbadboy
Honda Civic (2001 - 2005)
11
Dec 24, 2006 01:23 PM
lukas
Dec 28, 2003 03:32 PM
