iac? on 2000 ex
Old Mar 20, 2010 | 08:07 PM
2000ekex's Avatar
Default iac? on 2000 ex
car died while going down road one day, wouldnt start back, only thing we could get it to do was crank over. distributor was not putting spark to the plugs, so i pulled the cap and rotor button and replaced them, and still nothing. then replaced coil, and finally got spark car finally started and idled, but idles roughly now. doesnt miss while driving runs perfect while driving at constant speed. when i come to a stop light it idles down to about 400 rpms and tries to die if you turn the ac on it feels worse, and when the car is first started and motor is still cold it revs up slowly to 1800 rpms and varies from there. once it warms up it goes down to 1000 and varies from there. when you first start it up and motor is cold and it revs up slowly to 1800 if you rev it a little and let go of the throttle it goes back down to 900 rpms. could this be the iacv or the ditributor or what?? all input is thanked.
Old Mar 21, 2010 | 10:52 AM
CleanazzEJ1's Avatar
Default Re: iac? on 2000 ex
replace plugs new fuel filter and clean iacv then time your vehicle should run tip top after that
Old Mar 21, 2010 | 04:29 PM
2000ekex's Avatar
replaced plugs today runs a little better but still the same. where is the iacv at? is it somewhere in the throttle body?
DC2Mex
Sep 30, 2013 08:06 AM
elnoyl
Oct 16, 2010 02:03 PM
RALLYGSR79
Apr 3, 2009 01:52 PM
Ladiesx3Me
Mar 16, 2008 05:32 AM
