Spark Plug Wires into Distributor sequence or order
Old Sep 8, 2002 | 10:01 PM
hwnstyle21's Avatar
Default Spark Plug Wires into Distributor sequence or order
This is a simple one. I was wondering what the sequence or order was to plug the spark plug wires into the distributor. I know it for the B series but everyone told me itz different for the H Series. Basically what wire plugs up to what on the distributor? thanx
Old Sep 9, 2002 | 04:07 AM
H23 Power's Avatar
Default Re: Spark Plug Wires into Distributor sequence or order (hwnstyle21)
engine? year? model? etc etc
Old Sep 9, 2002 | 07:25 AM
Mikey3000's Avatar
bottom left is #1, bottom right is #2, top left is #3, and top right is #4
Old May 16, 2004 | 04:46 PM
londa hover's Avatar
Default Re: Spark Plug Wires into Distributor sequence or order (Mikey3000)
what is it for b- series?
Old May 16, 2004 | 07:04 PM
Wiseguy619's Avatar
1-3-4-2 is the firing order, w/ 1 being closest to the timing cover. And I am pretty sure that the bottom left on the dizzy cap is #1.
Old May 16, 2004 | 08:07 PM
neogenesis2004's Avatar
Default Re: Spark Plug Wires into Distributor sequence or order (ProjectPenny)
WOW, talk about bringing a post back from the dead. But I give this kid a for ******* searching. Good ******* job guy!!
Old May 16, 2004 | 08:23 PM
Default Re: Spark Plug Wires into Distributor sequence or order (neogenesis2004)
i do what i can.
and i can what i do.
Old Dec 30, 2004 | 07:36 PM
brookliner7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny &raquo;</TD></TR><TR><TD CLASS="quote">1-3-4-2 is the firing order, w/ 1 being closest to the timing cover. And I am pretty sure that the bottom left on the dizzy cap is #1.</TD></TR></TABLE>
is that the sequence starting from the bottom left of the dizzy? then continuing clockwise?
so plug wire #1 goes on the bottom left of the dizzy, and then #3 cable plugs in directly above that? and then it continues clockwise?
just pulled the dizzy off to replace, and my haynes manual is weaksauce!
Old Dec 31, 2004 | 07:25 PM
PrettyLude's Avatar
1 3 4 2 is right
kenny707
20
Jan 18, 2009 02:06 PM
ncsuprelude
Nov 13, 2006 08:30 PM
krazyteg
Apr 11, 2006 02:55 PM
Honda_18
Nov 27, 2004 10:07 AM
PatEJ6
Jan 20, 2002 12:57 PM
