2.0L GSR wont start after Re Ring
Old Mar 20, 2010 | 07:46 AM
HatchVX's Avatar
Default 2.0L GSR wont start after Re Ring
I have a 2.0L gsr turbo that after i had put new rings on it wont start. The car drove in fine on the Crome map i was running. Now if it does start, the throttle has to be held open to keep it running, then when you turn it off or it dies it wont restart. I have a strong spark on all 4 cylinders, I have 180 PSI compression across the board. And my fuel is at 40PSI. Timing is dead on also. i have tried other maps and none will work. Please any help will be great. sadly i dont have a wideband.
Patrick
Old Mar 20, 2010 | 07:48 AM
4g hatch's Avatar
Default Re: 2.0L GSR wont start after Re Ring
theres alot to check,but a head gasket will do that. did you install it upside down
Old Mar 20, 2010 | 07:50 AM
HatchVX's Avatar
Nah it was installed right
JDMkid413
15
Jun 9, 2009 02:59 PM
corince06
Nov 17, 2008 08:28 AM
jdmcivic1999
Feb 11, 2005 01:28 PM
VTcivicEG
Jul 19, 2004 01:51 PM
