VIDEO: 1996 Honda Accord Airbag Removal and Install
I could not find a good tutorial on how to do this, so I filmed mine with a GoPro Hero as a reference. I am not a tech, mechanic, or anything of the sort, so you will probably see 19 things I did wrong, etc. I am not claiming to be any kind of authority on the matter, just a guy that would have benefited from having something like this prior to doing the R and R.
I should also mention that I mistakenly purchased airbags for a 1995, and the plugs are different. I am selling a pair with module for only $300 if anyone is interested.
http://www.hondamarketplace.com/show...5#post41924195
Here ya go:
http://www.youtube.com/watch?v=dTFJiFHn0ks
Here ya go:
Did you follow the Helms or just wing it?
If you didn't follow the proper procedure you're luck the thing didn't blow up in your face. Seriously.
<- Removed his airbag
I'd also suggest you follow my bypass SRS procedure if you're going to an aftermarket wheel. That way your passenger air bag is still functional.
I asked two knowledgeable friends, and I understood that disconnecting the batter does not guaranty the will not discharge, but depending on how long they have been out it will decrease the likelihood.
I was aware it could discharge, but eh, it PROBABLY wouldn't have killed me, just a good punch in the face.
Where is the link to the Bypass SRS procedure? I am keeping the OEM but would like to see the link.
Accord FAQ - I believe it's titled "Bypass SRS System for Aftermarket Wheel"
Fairly simple procedure - and yeah the Helms has you disconnect the battery for 2-3 hours if I'm not mistaken (been awhile since I did it) prior to removing any of the bolts, namely those TORX bits that hold the bag on and then when you pop it out.
These bags were sitting for a week prior to installing. The old bags were already deployed, so I did the R&R. I am not experience, but I am not an idiot either, lol.
baceman007
Apr 29, 2015 05:58 PM
alok123
Nov 16, 2011 03:37 AM
