91 crx si chaking and vibrating
hello everyone i just have recently been experiencing some issues with my 1991 crx si, it has about 164k on it. the problem occurs when im starting out in first gear, the clutch and gears feel fine but when i let the clutch out normally the car starts shaking like crazy like its about to stall but doesnt, it shifts good into second then when i let the clutch out it shakes again. does any once have any ideas of what it could be?
thank you for any and all help.
can you be a little more detailed as to what is shaking like projekt90ef mentioned above? A quick response could be bad axles, clutch, anything drivetrain related...
Ok guys it's like when the car is about to stall the whole car has a shaking to it. Also now it's starting to make a knocking noise then I go. When I'm at the point where the clutch is grabbing it will shake like crazy. It seems if I rev it more it does not make the vibration as much
FR-MOB: ThE bEe GuY
Oct 19, 2002 10:11 PM
