Flywheel weights
Whatever you get, make sure you get one that has a replaceable friction surface.
I didn't look at the two you listed to see if they had it.
Fidanza does offer this feature.
Comes in really handy after you can't resurfacing it anymore ... better for the pocketbook than buying a whole new flywheel.
Also nice to have if your clutch ever blows up or tosses a spring and destroys the friction surface.
I much more beneficial could a 8.5lb flywheel be from a 12lb? Anyone have improved time slips with 12lb flywheel then with 8.5lb? Better gas mileage maybe? What else? Trying to justify the cost.
in other words your just buying a name!
wwll It's between my exedy and the bisimoto flywheel
exedy 10.8 lbs
bisimoto 9.7 lbs
I will also be running a shaved crank pulley
My real concern is drivability vs any real gains. a light crank pulley and flywheel, is that too much?
I heard too light flywheels cause shuddering?
exedy 10.8 lbs
bisimoto 9.7 lbs
Well stay away from the ebay aluminum pulley because it will virate and terminate your oil pump. Same seems to go for the CTR pulley.
I run a gsr pulley with the acc ribs shaved off along with my 12lb act flywheel.
I am happy.
I am happy.
I guess I want to know if the bisimoto flywheel will hold up.
Doesn't he use it in his 700 hp wagon?
. We use the lightweight flywheel on the 700hp wagon and even our daily wagons. This is also the same flywheel that was on the legendary Bisimoto CRX. Also, the friction plate is replaceable should the need arise
I spoke with you already.
I'll call Monday to place my order
I thats the flywheel Im gonna use, his **** rocks, cant wait to get my 3.6 cam
Sounds Good!!
I call Bisimoto tech and The guy told me theirs are already balanced
The recommend that you balance flywheel with your clutch pressure plate.
You should consider doing this with any flywheel you buy... doesn't matter if they balanced the flywheel by itself or not.
It's always good to balance assemblies - just like wheels, it would be really stupid to balance the rim with no tire.
