Various Headers Specs for B series
Old Sep 8, 2002 | 08:46 PM
vtec.dc2's Avatar
Default Various Headers Specs for B series
just trying to gather information on various headers.
please reply to ad more details or correct..
this is what i got so far:
IB JG Edelbrock 4-2-1: 44.45mm OD A section --> 50.8mm OD B section --> 63.5mm OD collector
Toda 4-2-1: 45mm OD primaries --> 50mm OD secondaries --> 60mm OD --> 63.5mm ID / 65mm OD collector
Type One 4-2-1: 48mm OD primaries --> 60mm secondaries --> 65mm OD collector
Honda 98Spec JDM 4-1: 42mm OD primaries --> 57.2mm-63.5mm ID / 65mm OD collector
DC JDM 4-1: 44.5mm OD primaries --> 63.5mm ID / 65mm OD collector
Comptech 4-2-1: 38.1mm OD --> 41.3mm OD primaries --> 44.5mm secondaries --> 50.8mm OD collector
DC 4-2-1: 41.3mm OD primaries --> 44.5mm OD secondaries --> 50.8mm OD collector
SMSP 4-2-1: 63.5mm OD collector
Jun 4-2-1: ?
Hytech 4-2-1: 63.5mm ID/ 65mm OD collector?
Spoon 4-2-1: 63.5mm ID/ 65mm OD collector?
Mugen 4-1: 45mm OD primaries --> 63.5mm ID/ 65mm OD collector?
Mugen 4-2-1: 44.45mm OD primaries --> secondaries --> 63.5mm ID/ 65mm OD collector?
Type1 4-1: 63.5mm ID/ 65mm OD collector?
Will ad lenght/other dimentions, if available
[Modified by vtec.dc2, 12:29 PM 10/14/2002]
Old Sep 8, 2002 | 09:14 PM
SurferX's Avatar
Default Re: Various Headers Specs for B series (vtec.dc2)
Are we talking OD or ID measurements?
Old Sep 8, 2002 | 09:17 PM
vtec.dc2's Avatar
Default Re: Various Headers Specs for B series (SurferX)
ID
Old Sep 8, 2002 | 09:40 PM
SurferX's Avatar
So you're saying those headers have a 63.5mm ID collector? That'd be 2.5" on the ID for the collector for those headers which I thought were 2.5" OD.
Old Sep 8, 2002 | 09:59 PM
vtec.dc2's Avatar
i'm not exactly sure.. that is information i gathered from searching around
http://www.ipsracing.com/engine/headers/toda_421.html
http://tech.hybridgarage.com/tech/jdmhdr/index.html
http://www.edelbrock.com/
once i know for sure i will correct the first post..
btw.. trying to gather ID measurments
Old Sep 8, 2002 | 10:38 PM
RICHJ's Avatar
OD will be simpler i.e. people can go out and measure the pipe work, ID can be worked out if wall thickness is known in the case of the primaries and b-section, but the collector may be a problem as some are double layered like the Honda JDM one and some like the DCSport JDM 4-1 aren't.
I can probably measure the ODs on my DCSport JDM 4-1 for you later.
Old Sep 8, 2002 | 10:44 PM
vtec.dc2's Avatar
Default Re: Various Headers Specs for B series (RICHJ)
sounds good.. i'll just add both ID and OD to the first post, whatever information is available
Old Sep 8, 2002 | 10:49 PM
SMSP's Avatar
Almost all the JDM 4-2-1s (Toda, Jun, Spoon, T1) are 45mm Primaries and 50mm secondaries. These are of course OD measurements because tubing is spec'd by OD x wall thickness. The Mugen 4-1 has 45mm primaries. The DC JDM has 1-3/4" primaries. All the above have 65mm OD collectors. Each of the designs taper to the 65mm intheir ownway.
The Comp Tech 4-2-1 has 1-1/2"x1-5/8" stepped primaries and 1-3/4" secondaries with a 2" collector. The DC 4-2-1 has 1-5/8" primaries and 1-3/4" secondaries with a 2" collector.
Old Sep 8, 2002 | 10:55 PM
Tommy_Gunns's Avatar
Default Re: Various Headers Specs for B series (SMSP)
I have a Vernier's caliper, if I remember, next time I do an oil change I'll measure the dimensions on my header.
Old Sep 8, 2002 | 11:09 PM
RICHJ's Avatar
"Metricized" so easier to compare... 1 Inch (in) x 25.4 = Millimetres (mm)
Rounded to nearest 1/2mm
DC JDM 4-1: 44.5mm primaries --> 65mm collector.
Comp Tech 4-2-1: 38mmx41mm stepped primaries --> 44.5mm secondaries --> 51mm collector.
DC 4-2-1: 41mm primaries --> 44.5mm secondaries --> 51mm collector
[Modified by RICHJ, 8:12 AM 9/9/2002]
Old Sep 9, 2002 | 07:54 AM
vtec.dc2's Avatar
updated..
Old Sep 9, 2002 | 08:24 AM
SMSP's Avatar
The IB JG Header collector is 2-1/2" OD as is mine. Just the JDM headers have the 65mm OD collectors.
Old Sep 9, 2002 | 08:33 AM
vtec.dc2's Avatar
thanks.. got it updated
7rrivera7
Nov 2, 2003 04:04 PM
integsr99
Jul 8, 2003 10:30 AM
IC x Prince
Mar 7, 2003 06:36 AM
RedStarGsr
Feb 21, 2002 05:56 PM
