Oil in coolent resevoir-Y8- help!
Old Mar 19, 2010 | 10:47 AM
NACE42's Avatar
Default Oil in coolent resevoir-Y8- help!
just found out today that oil magicly appeared in my coolent resevoir. idk when that happened but it did. was curious to kno if it is the head gasket or can it come from other places as well? help appreciated.
Old Mar 19, 2010 | 11:03 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Oil in coolent resevoir-Y8- help!
I don't believe there is any other place for oil and coolant to mix other than where the head meets the block. Check your radiator too for oil. Pretty certain it's the headgasket.
Old Mar 19, 2010 | 12:21 PM
Jockone's Avatar
If the car is an auto then the radiator could be bad between the oil cooler and the coolant side of the radiator,mixing tranny fluid with coolant would look pretty much the same.
If the car is a stick shift then it is most likely the head gasket.
Check your oil and see if it looks like malted milk.
cristegra09
May 14, 2009 11:45 AM
johnnyqsack
Sep 18, 2006 09:01 PM
mingbling96
Jan 17, 2005 09:31 PM
92jdmhatch
10
Dec 28, 2004 07:53 PM
92hybridAccord
Nov 26, 2003 04:05 AM
