brake conversion Q
Old Mar 19, 2010 | 09:26 AM
b18c1del's Avatar
Icon2 brake conversion Q
would a 40/40 prop valve from 90-93 DA work
with 94-01 DC gsr f & r set up > help A-S-A-P
** do i need the brake booster too ?
Old Mar 19, 2010 | 10:01 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: brake conversion Q
yes the prop valve is the same.
yessssssss take the brake boost and MC it helps alot.
i did the same thing
Old Mar 19, 2010 | 02:01 PM
b18c1del's Avatar
did u hv to modify the brake lines into the prop valve >
some say booster yeah but M/C not necessary ? thanx 4 reply
Old Mar 20, 2010 | 08:15 AM
I'm not Rick!
MC has a bigger bore in it. so grab that too. but you can use your stock filler cup. (smaller)
no i didnt change anything with the line. from a DA it bolts dircetly on an EG. with no midification. GL under the dash of the DA though...its real hard get the boost nuts off.
the eg is real easy though. (more room)
1SlowSi
Suspension & Brakes
Dec 27, 2008 11:14 AM
badpootie
12
Apr 17, 2005 08:44 AM
midnightdarknes5
26
Jun 15, 2004 06:26 PM
