Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
** COILOVERS!! THE END ALL THREAD : F2 Tein GC/Koni Yonaka Megan KSport More **
Old Mar 19, 2010 | 08:40 AM
Dan@Assaultech's Avatar
Default ** COILOVERS!! THE END ALL THREAD : F2 Tein GC/Koni Yonaka Megan KSport More **
Assaultech Turbo T-Shirts Available - Only $15-$20 shipped - LE Colors Available - CLICK HERE TO ORDER
Function & Form Coilovers
Get Slammed!!
And Still Ride In Comfort
Function & Form Type I Coilovers
$$ Price to Low to Advertise - Call Us $$
Function & Form Type II Coilovers
CLICK HERE TO GET TO OUR SITE TO ORDER
(BE SURE TO USE PROMO CODE MODIFIED)
Kontrol Pro Coilovers
Product Description
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in
suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
FEATURES
  • 36-way adjustable dampening
  • Made from high quality 6061 Aluminum with T6 for increased hardness
  • Compression/Rebound adjustable
  • Adjustable spring perch for height adjustment
  • Adjustable body allowing maximum suspension travel
  • Pillow Ball Top Mount w/ adjustable camber (not available for some models)
  • Monotube High Pressure Design reduces oil leakage
  • Electroplated body for protection from corrosion and rust
  • One Year Limited Warranty
GT Pro Coilovers
Product Description
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and
braking system reducing heat transfer This design also reduces under-sprung weight, which improves handling and responsiveness.
FEATURES
  • Inverted steel shock absorber for durability
  • Lower center of gravity and higher chassis rigidity
  • Designed to reduce friction for cooler shock oil temperature
  • Inverted design like vehicles in WRC and all JGTC cars
Fitments
01-05 Civic Click For More Info & To Order
02-05 Civic Si Click For More Info & To Order
06+ Civic Click For More Info & To Order
KSport GT Lowering Springs
TEIN S-TECH LOWER SPRINGS
ADD TO YOUR CART & USE PROMO CODE MODIFIED TO SEE YOUR PRICE & ORDER
ALL APPLICATIONS // CLICK HERE TO ORDER
TEIN H-TECH LOWER SPRINGS
TEIN BASIC COILOVERS
TEIN SUPER STREET COILOVERS (SS)
TEIN SUPER STREET COILOVERS (SS-P)
WITH PILLOWBALL UPPER MOUNTS
TEIN FLEX COILOVERS
TEIN MONO FLEX COILOVERS
TEIN COMFORT SPORT COILOVERS
^^ RSX COILOVERS ^^
^^ PRELUDE COILOVERS ^^
^^ CIVIC COILOVERS ^^
Features
  • All Aluminum Upper Mounts
  • 0-4" Height adjustment.
  • Fully Threaded Mono Tube Shock Absorber.
  • Inner bump stop to prevent damage cause by rapid compression impacts.
  • Wide range of height adjustment without changing the spring compression.
  • Bottom of the shock is threaded to allow height adjustments without having to shorten the suspension travel.
  • Rubber dust shield protecting piston for long life.
  • Adjustment tools included.
$549 Shipped
92-95 Civic / 93-97 Del Sol
96-00 Civic
88-91 Civic
94-01 Integra
$699 Shipped
92-96 Prelude
02-06 RSX
Koni & Ground Control : Total Control Setup
Limited Time!!
Starting at Only $849 shipped for Koni + Ground Control Combo
Megan Racing Street Series Coilovers
All other Megan Racing Products Also Available!! Just ask or visit our site.
Skunk2 Pro Series Coilovers
Pro-C & Pro-S
Just Use Promo Code MODIFIED!
Your direct source for performance coilovers!
There are a few brands that are not listed, but we have great deals on them too.
Eibach, Koni, Tokico, KYB ..... and more Im sure
Old Mar 22, 2010 | 12:43 PM
kleen98accord's Avatar
Default Re: ** COILOVERS!! THE END ALL THREAD : F2 Tein GC/Koni Yonaka Megan KSport More **
Pm'd.
Old Mar 23, 2010 | 12:48 PM
dandaman15's Avatar
Community Builder
How much for FF type 1s for a 98 civic?
Old Mar 23, 2010 | 12:56 PM
Thanks for hitting us up. You have a PM!
Old Mar 24, 2010 | 03:06 PM
All PMs Sent!! Bump to the Top!
Old Mar 25, 2010 | 02:43 PM
Old Mar 25, 2010 | 04:41 PM
94CivTLC's Avatar
Are you still offering the Koni Yellows + GC's for 750$ & free shipping??? Do you carry them in stock?
Im interested... Shoot me a PM. Car is a 94 coupe (EJ) Thanx!
Old Mar 26, 2010 | 07:07 AM
Old Mar 26, 2010 | 01:35 PM
Old Mar 27, 2010 | 08:23 AM
Old Mar 28, 2010 | 07:02 AM
justlook's Avatar
96-00 Civic
Type II
Koni with GC
shipped to 70072?
Old Mar 28, 2010 | 08:26 PM
bren94cx's Avatar
how much for tien basic or meggan shipped to 06043
Old Mar 29, 2010 | 01:57 PM
Originally Posted by justlook
96-00 Civic
Type II
Koni with GC
shipped to 70072?
Old Mar 29, 2010 | 06:30 PM
98spyderman's Avatar
TRIAL USER
How much for FF type 1s for a 00 Si shipped to 21061?
Old Mar 30, 2010 | 09:22 AM
Old Mar 31, 2010 | 03:14 PM
Old Apr 1, 2010 | 09:53 AM
Old Apr 2, 2010 | 02:52 PM
Old Apr 2, 2010 | 09:57 PM
b16a92teg's Avatar
TRIAL USER
how much for 92 integra gc/koni setup sent to toronto canada l6y5b4?
Old Apr 4, 2010 | 11:42 AM
Salvi-EJ1's Avatar
Do you guys have PIC Apex coilovers for a 95 civic? If so, how much?
How much for function and form type 1's for a 95 civic?
Old Apr 6, 2010 | 06:35 AM
Dang EG's Avatar
Could you send me the best price for KONI/GC with top hats to dkn920@gmail.com
I will be away for a while and need to make a decision on this asap. Thanks...
Its for a 95 Civic HB CX
Old Apr 6, 2010 | 07:19 AM
Black Diamond's Avatar
FF type ones shipped to 19904
LMK
Thanks, BlackDiamond
Old Apr 6, 2010 | 12:56 PM
Everyone has been PMed, sorry it took so long guys. Got a crazy backup after easter weekend.
Old Apr 8, 2010 | 02:01 PM
Old Apr 9, 2010 | 11:31 AM
Its finally Friday!! Hope everyone has a safe and great weekend. Remember we are opened on Saturdays!
