Suspension & Brakes Theory, alignment, spring rates....
rebuilding neuspeed coilovers?
Old Mar 19, 2010 | 08:30 AM
slateEKsi's Avatar
Default rebuilding neuspeed coilovers?
Is there any disadvantage to getting the shocks of my neuspeed full coilovers rebuilt? (bilstein shock) I know they wont look brand new when i get them back, but other than that, wont they pretty much be brand new or am i missing something?
Old Mar 19, 2010 | 07:17 PM
Meoshe's Avatar
Default Re: rebuilding neuspeed coilovers?
No disadvantage really besides the cost.
Old Mar 20, 2010 | 07:40 AM
Trey's Avatar
25 Year Member
It's $65 per shock. That is cheap! Call and talk to them. They are really helpful.
http://www.bilsteinus.com/services.php
edit:
Just realized you are the same dood from the other thread. Yea...just call them and talk to them. As long as the internals aren't damaged (bent rods) it will be like new for pretty cheap. If they have to replace internal parts it can add up but still be cheaper than new.
Old Mar 21, 2010 | 07:09 AM
slateEKsi's Avatar
do you recommend anything else besides the basic rebuild? like new piston rod and or anything else?
Old Mar 21, 2010 | 08:38 AM
02aspenWrx's Avatar
TRIAL USER
Yes, +1 on this. I don't think there are really any disadvantages.
Old Mar 21, 2010 | 10:47 AM
STOCK_SOHC_DX's Avatar
Unless your piston or shaft is damaged you shouldn't need replacement. Because that kit is kinda old I would recommend getting all your shocks rebuilt by them. BTW I was under the assumption that Bilstein shocks were/are lifetime warranty? You might want to inquire about that.
Old Mar 21, 2010 | 04:24 PM
Trey's Avatar
25 Year Member
+1 ^^
You need to do all of them at the same time or it will ride weird.
Old Mar 22, 2010 | 01:06 PM
slateEKsi's Avatar
i will be getting them all rebuilt at the same time... no use just doing one when they all could blow any minute... I would inquire about the warranty, but i'm not the original purchaser of these coilovers so i'm assuming they wouldnt honor the warranty without a receipt- what do you guys think about getting the "tube replacement" ? what does that even mean ha?
Old Mar 22, 2010 | 05:07 PM
Trey's Avatar
25 Year Member
Sounds painful!!
I think if you get in an accident and bend the tube, they will replace it. Just ask them to be sure. They are cool to talk to.
Purple_pigeons
Oct 26, 2018 04:39 AM
TurbodreamZ
Sep 1, 2007 07:58 AM
simplegreenmachine
Mar 4, 2003 07:41 PM
