electrical problems in 90 si
Old Mar 18, 2010 | 09:10 PM
90honduh's Avatar
Default electrical problems in 90 si
ok i rebuilt a y8 and put my car back together. my blinkers and tach and fuel and temp gauges werent working. i replaced my turn signal fuse and a few other fuses and everything worked abut fuel and temp. i also had my power wire for my cd player ran to my turn signal fuse and it was working too. one day my cd player,blinkers, fuel, temp, and tach stopped working. so i pulled my blinker fuse and it was fine. i ran my cd player to a different fuse and it works noe. but i still have no power to my blinker fuse and tach and fuel and temp doesnt work. note: my hazards still work
Old Mar 18, 2010 | 09:47 PM
Fo-Do Fanatic's Avatar
Default Re: electrical problems in 90 si
Just because the fuse "looks" good, doesn't mean it's actually good. Just replace it with another one and see if it works.
Old Mar 19, 2010 | 12:54 AM
90honduh's Avatar
no go..... i even tried a diff cluster.
Old Mar 19, 2010 | 02:39 AM
have you simply just replaced the fuse or tested the fuse? hooked it up to a DMM and test for teh resistance of the fuse.... if you get a good reading of the fuse OTHER than OL then it's good. Then we'll go from there....
tacpsi
Sep 23, 2019 06:20 PM
walsh22
Jan 9, 2007 03:25 PM
nObOdy65
Feb 22, 2006 07:36 PM
crxdriver
Audio / Security / Video
Aug 23, 2002 07:11 AM
