Exceeding load capacity on Accord
Old Mar 18, 2010 | 07:51 PM
go_honda's Avatar
TRIAL USER
Default Exceeding load capacity on Accord
We had some visitors over the weekend and I ended up driving everyone around (total 6 people) in my 2000 Accord. I think we drove a total of about 200 miles. I checked the load capacity on the side of the car door today and it says 850 pounds. I'm guessing, with 6 people we were around 950 pounds. Should I be concerned?
Old Mar 18, 2010 | 07:58 PM
GhostAccord's Avatar
Default Re: Exceeding load capacity on Accord
Did she seem like she was struggling real bad while you where driving over capacity? If not I wouldn't worry about it. They are built tough enough to take 100lbs over there rated capacity. Unless you are starting to hear strange sounds from the transmission or engine. Or if you are seeing smoke coming from the exhaust.
Old Mar 19, 2010 | 03:19 PM
go_honda's Avatar
TRIAL USER
Thanks for the reply. No unusual sounds yet from the transmission or engine. I was also worried about the tires-- if the overload could have somehow weakened them.
Old Mar 20, 2010 | 04:04 AM
I'm pretty sure your tires should be fine. If it was enough to weaken them, you probably would have known right then and there.
Old Mar 20, 2010 | 08:25 AM
TheMuffinMan's Avatar
He knows where you live!
The only thing with your tires would have been increased camber due to the weight (where they're sunken inwards at the top) the distance you drove however was minimal and would have have caused any lasting effects. You could if you were **** about it look over your joints to see if you broke any old rubber bushings from the increased stress but I doubt anything is actually wrong or damaged.
jc1082
Sep 12, 2015 09:52 AM
Sumr
24
Jun 12, 2012 10:41 AM
Blamm!!
Nov 26, 2009 08:44 PM
M0NEYnH0s
Mar 16, 2006 02:23 PM
Mocky57
Apr 9, 2003 09:09 AM
