Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
More civic cold start issues, What OBDII PC software??
Old Mar 18, 2010 | 06:09 PM
jrm's Avatar
jrm
Default More civic cold start issues, What OBDII PC software??
I have 2 01' civic an auto for my wife and a 5 speed for myself purchaced new and pampered with amazing maintence as I intend for both of these cars to reach 500k with our 100 mile per day commute to work.
Both have around 140,000 on them and drive like new except both of them are starting to have issues on cold starts-
The other night i moved my civic from our heated garage outside into 28F air so I could work on my zx10R, the car sat outside all night and the next morning the outside air temp rose from freezing up to 60F in a couple hours as a southern weather system moved in so the engine block was still freezing but the outside air temp was warm. I tired to start the civic and it stumbled to life then died, i tried to re-start 2 times by cranking for 5 seconds at zero throttle each time. 100% Nothing, as if it was super lean- so i grabbed my i phone and took a video on the next try, and it started rough, ran at 400 RPM then slowly rose to normal as seen in the video duing the beeping. Exahust was not rich and seemed as if the ECU had the jetting spot on- both civics only have this issue if started and shut off on a cold engine and let sit for hours before the next re-start so im sure its ECU memory-- What good OBDII PC software can i buy to analize what sensor or componet is at fault? Im willing to spend $500 or so as I have two civic's and one 2010 Accord in the family.
http://www.youtube.com/watch?v=3z4EWzyT77s
Thanks, Joe
Old Mar 18, 2010 | 10:56 PM
wickedbautista's Avatar
Default Re: More civic cold start issues, What OBDII PC software??
well you have no check engine light so scanner might not pull anything
Old Mar 19, 2010 | 02:55 PM
killaxkev92288's Avatar
try giving it a tune up and see what that gets you
Old Mar 19, 2010 | 08:57 PM
jrm's Avatar
jrm
its been overly maintained, trust me im crazy **** (gigidity) to the point i change the clutch and brake fluid every 50k and irudium plugs ever 75k- transaxle oil every 25k, amsoil 5w30 changed every 5k, cabin and engine air filter every 20k etc etc. It runs and drives perfect except this cold start thing-- not wanting a scanner i would rather have the full PC software to monitor everything that the OBDII can so i mite be able to spot a randomly faulty sensor? It should get the startup jetting from both the outside air and coolant temp sensors right?
Old Mar 19, 2010 | 09:06 PM
jrm's Avatar
jrm
Just spoke with a friend thats a street bike mechanic with lots of experence, he is on board with jetting being number one cause but also asked when the last time I adjusted the valves---- that would be never- do these D17 engines have valves that tighten up? I do drive pretty hard as its rather gutless so im sure the EGT's with the cat right below the manifold have been ultra high with my 4th gear 80MPH pull up a 10 mile long 8% hill on my daily commute!
Old Mar 20, 2010 | 02:07 AM
wreck187's Avatar
scan it see what u get??
Old Mar 22, 2010 | 02:42 PM
Icon6 Re: More civic cold start issues, What OBDII PC software??
yes, a valve leash adjustment can be perform on the d17
chevisregal
11
Mar 8, 2024 04:19 PM
Plecotus
Honda Civic (2006 - 2015)
Feb 21, 2014 12:51 PM
bfrito
Jan 14, 2011 02:12 PM
cromais
Jul 6, 2004 11:59 AM
