View Poll Results: which would you perfer
Voters: 66. You may not vote on this poll
which car is better?
The hatchback shape of my ITR was very handy, and it could carry things that even my parents' larger cars could not. I'm assuming the same goes for the RSX.
With the Si coupe, you get all the drawbacks of the 3-door hatch with none of the benefits. Kinda sucks.
And I'm guessing the CTR is a sedan because a 4-door body is usually more rigid than a 2-door body. 4 small holes > 2 large ones.
^ the lsd is crucial. Especially once you start modding. With very short gearing and a 4.76 differential at times it can be hard to use 1st without spinning so the lsd helps quite a bit.
Believe it or not, coupe really has nothing to do with how many doors there are on a car. It's the chassis and position/design of the pillars that really determine it. There are 4 door coupes and 2 door sedans.
if you were researching a honda civic si coupe vs a rsx type-s (05 model) than i would go for for the rsx. The looks, performance and interior are just so much better than 8th gen civics.
2010's.
i guess your right
