why the difference in DX prop valves for 2dr/3dr vs 4 dr?
I've been doing some research on what should be changed when a DX is converted to SI/GSR brakes.
Apparently the SI prop valve is the same as the DX 2dr/3dr but not the same as the 4 dr sedan.
Anybody know why the difference in prop valves? the part numbers are different too. i own a 96 DX.
I don't really want to spend time swapping it unless it's truly necessary.
Thanks
Thanks
4 doors came with either bigger drums or rear discs with abs, neither of which is what you are looking for. If you are looking to put rear discs on you need a prop valve off a non abs del sol w/ rear discs, integra rs, or a non abs civic with rear discs(don't remember which usdm ones if any came with that combo).
46210-S04-952 VALVE ASSY., PROPORTIONING 1998 INTEGRA RS
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC CX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC HX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC SI Coupe
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX-V Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC LX Sedan
46210-S04-922 VALVE ASSY., PROPORTIONING 2000 CIVIC GX Sedan
46210-S04-962 VALVE ASSY., PROPORTIONING 2000 CIVIC EX Coupe
CustomX113
Dec 9, 2006 09:47 AM
