blown k20a2
Old Mar 17, 2010 | 10:11 PM
tweek_boii's Avatar
Default blown k20a2
i was speeding went from 5th to 4th on really high RPM's . pull over and motor no longer turns on. no hole on my block. there is still oil in it, i checked out my spark plugs and one of them is crushed ?
Can any one here, who has had their engine rebuilt, give me an idea how much it cost total ?
Old Mar 17, 2010 | 10:14 PM
b18_bcivic's Avatar
Default Re: blown k20a2
from 500 to 1800 depending on where u go and wat u want done
Old Mar 17, 2010 | 10:23 PM
YaBoiTHiZZ's Avatar
Damn more info on what happened...
Old Mar 17, 2010 | 10:28 PM
tweek_boii's Avatar
rebuilt with normal parts, non racing ..
Old Mar 17, 2010 | 11:07 PM
YaBoiTHiZZ's Avatar
Ouch...yea that motor is done. That spark plug alone could have done alot of damage do you have any pics of the damage...
Old Mar 17, 2010 | 11:41 PM
tweek_boii's Avatar
woa. so motor is useless ?
no pics yet but soon
Old Mar 18, 2010 | 01:20 AM
YaBoiTHiZZ's Avatar
You won't know till you tear it apart...
Old Mar 18, 2010 | 10:35 AM
tweek_boii's Avatar
Alright, thanks for the heads up. I will post pics of any updates
Old Mar 19, 2010 | 03:47 AM
dx_rex's Avatar
motor is probably usless. that could cause major damage to the head and block... if you remember the pics from this thread.. i guess the only way to find out is pull the motor.. you may find it easier to just get a new engine tho..?
https://honda-tech.com/forums/showth...ighlight=blown
Old Mar 19, 2010 | 10:58 AM
WhiteOnRice's Avatar
Sorry to hear but high rpm's in 5th? That miss-shift may have saved some lives. Good luck though Tweek, hopefully it works out.
Old Mar 19, 2010 | 02:05 PM
tweek_boii's Avatar
The closest thing to a new engine is by rebuilding one..
Thanks and the positive thing is I learned my lesson.. Our families are out there..
Old Mar 22, 2010 | 06:09 AM
turboteg2nv's Avatar
Agreed, stop speeding like a jackass and learn how to drive.
Old Apr 2, 2010 | 08:35 PM
ADR33's Avatar
haha i did the same thing. only i was in 3rd at about 6.5-7k rpms and miss shifted to 2nd.
Old Apr 2, 2010 | 10:19 PM
cloumep3's Avatar
f*ck!?!?
Old Apr 3, 2010 | 10:02 AM
iv's Avatar
iv
WOW that sucks
Old Apr 4, 2010 | 10:42 PM
ADR33's Avatar
yea it does. ima try to see if i can get some one to open it up to see if its rebuildable. i hope it is if not ill just get a another k20.
Old Apr 10, 2010 | 02:33 PM
tweek_boii's Avatar
Broke a lot of things..
I found a deal on a k20z1 long block, can I put this on my 04 with out any trouble ?
Old Apr 10, 2010 | 03:30 PM
K20egcw's Avatar
Yeah it'll go right in your 04
Old Apr 11, 2010 | 09:13 PM
tweek_boii's Avatar
awesomeness, several people have convinced me. Well I'll try my luck and go through the deal with this dude..
hope the motor runs.
Old Apr 11, 2010 | 11:23 PM
TurboK's Avatar
Ouch!....hope it all works out for you
Old Apr 13, 2010 | 09:07 PM
ADR33's Avatar
you will new that engines ecu and mostly likely its wiring harness. im not sure about the charge harness.
Old Apr 18, 2010 | 03:03 PM
burnykawizzle's Avatar
just change your pistons with oem.... fully build your head with aftermarket valves and springs and next time you miss shift you wouldn't have that problem!!!!!! rebuilding your head will make it 0miles instead of buying another k20 not knowing the condition the motor is in... you will spend like 1000 but hey!!!! its worth the money because your sleeves look fine so just
Old Apr 18, 2010 | 06:19 PM
ADR33's Avatar
Hey one quetion. Did you find any pieces of metal anywhere in your engine? If yes where? And do you had a picture of the bottum of the head the part that sits on the block? I would to see the damage to estimate mine.
Thanks in advance for the help
Old Apr 18, 2010 | 08:09 PM
as long as the engine didn't overheat when it blew... im sure their shouldn't be any warp and should be able to rebuild.. maybe not oem but at least bigger pistons and head work theres no point in throwing away an engine that can be restored to buy another engine... you just never know what condition the other one is and at least with a fully built engine youll know what its about!!!! why spend 1200 on a working k engine when you can put that toward yours and make it 0 miles!!!!
Old Apr 18, 2010 | 08:34 PM
ADR33's Avatar
True. But I wanted it done quick and it was going to cost me more to fix it. So I decided to get a new engine. Plus once my engine was out I saw piecess of aluminum in my intake manifold! I was like WTF! Do you wat that could be? I ask the guy who's doing the transplant what that could be. He told it looked like it was my pistons. Cause along with the pieces was wat looked like a pistion ring.
