my gas milage sucks. whats wrong?
Old Mar 17, 2010 | 01:56 PM
michael-crxsi's Avatar
Default my gas milage sucks. whats wrong?
EDIT with the question. how many miles should i be getting from a full tank out of a stock 91 si crx d16a6?
im getting about 250 miles per tank. when i fill it up i get to about half tank with 150 miles but then it kinda drops fast from there which leaves me getting about 190-240 miles per the tank fill.
i have a 91 crx si with a stock d16a6 engine. i had a camber issue really bad and i thought that was it but i got it fixed and i still have bad MPGs
Old Mar 17, 2010 | 02:18 PM
4g4dcruisin's Avatar
Default Re: my gas milage sucks. whats wrong?
-Any check engine lights coming on?
-Any smoke coming from the tail pipe? If so, what color?
-Smell of fuel in the cabin/engine bay?
Old Mar 17, 2010 | 02:23 PM
BiG ChOr!Zo's Avatar
sounds like you need a complete tune up in your cars diet...!!!
Old Mar 17, 2010 | 02:27 PM
LastGenEK's Avatar
tune up! or your gauge is messed
how are you getting your mpg calulations?
I not questioning your smarts at all dont take it the wrong way
i have a turbo gsr, its a little better
not by nuch
i get about 195-210 miles to about 11.2 gallons
roughly 18mpg mixed driving
Type r tansmission
Old Mar 17, 2010 | 02:49 PM
NO check engine lights, no smoke that i know of. i do smell gas sometimes when i park my car and get out but its no to strong but i can smell it.
i got my spark plugs replaced my my friend mechanic/uncle but i found out hes not to be trusted so no clue if that even really got done
not by nuch
Type r tansmission
is there a correct way to calculate MGP? i wasn't to sure about that
Old Mar 17, 2010 | 02:52 PM
a complete tune up consists of way more items than just changing spark plugs
Old Mar 17, 2010 | 02:59 PM
i think he had done just plugs and wires. ill look for the invoice
Old Mar 18, 2010 | 04:08 AM
zapzach's Avatar
i have a similiar problem with my 90 civic hatch D15B2.
**** gas mileage, white smoke, and the smell of gas.
i know the head gasket is shot. but does that effect your gas mileage?
also my IAC valve is ****, i have to clean it out every couple months.
any suggestions. i was just going to swap in a D16a6 mpfi and call it a day.
will a D16a6 bolt up to my std 4 speed tranny? do i need harnesses, axles and what not?
Old Mar 18, 2010 | 05:43 AM
vanion2's Avatar
You should do some searching for engine swaps and start your own post instead of thread jacking someone else's.
Old Mar 18, 2010 | 05:49 AM
vanion2's Avatar
You're running rich for some reason. Take it to a reputable mechanic (or get a good manual) and get a real tune up done.
Fill up the tank, reset your trip odometer to zero. Next time you fill up write down the number of gallons you put into the tank. Take your miles and divide by number of gallons to get a good estimate. Repeat for about a month and take the average. This gives you a pretty precise estimate of your gas mileage.
Check tire pressure.
Stay away from ethanol mixed gasoline if you can.
Tune up should be a top priority here.
My d16a6 was averaging 30 mpg in city driving and 40 mpg highway.
Old Mar 18, 2010 | 07:10 AM
chivid's Avatar
also the fuel pressure regulator could be bad causing too much fuel to flow in the fuel rail
Old Mar 18, 2010 | 07:32 AM
If ur running rich, that means FUEL>AIR, so you must have a faulty fuel pressure regulator, or leaking injectors.
Does the car sometimes NOT start up on the first try?
Old Mar 18, 2010 | 11:45 AM
skipbudlong's Avatar
Same problem on my b16 obd-0. Strong smell of gas, crap gas mileage. Has to be something universal if all of us are having this problem. My car always turns on but roughly. Ive noticed it turns on right away in the heat with no problems. Who's got the solution?
Old Mar 18, 2010 | 12:05 PM
It should be a sticky somewhere, but if you have the smell of fuel in your engine bay or while driving it, then your problem can ONLY be a few things.
-fuel injector dripping into the cylinder instead of spraying
-fuel injector o-ring wearing down, or the rubber gasket that is pressed between the fuel rail and injector body.
-FPR faulty, i dont know how it goes bad, but it could result in pushing out too much fuel into the cylinder.
-leak in fuel lines either coming from the tank, or the lines from the fire wall into the fuel rail.
The fuel system is probably the easiest to work on, you dont have to open the head/block to get to the guts. Everything is right there, and could only be so many things wrong.
Some other problems that are "user error"...
-high flow fuel pump (turbo applications)
-high cc injectors
-high flow fuel rail
^^those "should" be used for turbo applications, remember, the ratio of fuel has to be equal to the ratio of air. So, in turbo, you got all that air, you need a **** load of fuel while spooling.
Old Mar 19, 2010 | 01:41 AM
IM surprised there isnt someon on here that had this problem and fixed it.
Old Mar 19, 2010 | 05:24 AM
vanion2's Avatar
Feel free to be the first.
Old Mar 19, 2010 | 06:35 AM
Read my posts, check what i mentioned, come back when fixed/replaced.
Old Mar 20, 2010 | 09:13 PM
my car starts up first time every time.
what should my tune up consist of?
Old Mar 22, 2010 | 07:35 PM
how do i check that?
should i check my fuel filter or anything like that?
Old Mar 24, 2010 | 02:08 PM
anyone?
Old May 9, 2010 | 06:05 PM
Old May 9, 2010 | 06:26 PM
Jorsher's Avatar
How I test mileage:
- fill up tank
- set tripometer
- next fill up, write down how much gas it took to fill it, the miles on the tripometer, and reset
- divide miles/gallons
For reference, I got 32-35mpg of mixed driving on my LS-VTEC CRX ... so yours definitely sounds low.
Old Jun 26, 2013 | 08:31 PM
v-tec.cte-v's Avatar
Icon3 Re: my gas milage sucks. whats wrong?
I have a 94 civic si with a b16a swap and im having the same problem. I really think that it has something to do with the sparkplugs but hopefully not much else. my car starts up first time and the smell of gasoline comes in waves.
i need help!
Old Jun 27, 2013 | 05:45 PM
Laserjock's Avatar
Most fuel gauges for these years are almost 1 gallon off. It reads low when there is really 1 gallon in the tank. When I do the calculation described above, and I refill with 1/4 tank of gas it comes out to around 26 - 28mpg. This is recorded over 4 months of daily driving.
I've ran 355 miles out of my RT4WD wagon. 91 All stock. . . then I ran out of gas! :] LOL
I now keep a 1 gallon of fake fuel in the car and rotate it every 6months or so. And fill up at around 330 - 340 miles. Im averaging around 29 - 31 mpg
Most states have ethanol (thank you corn lobbyists and tree-huggers = usux!) and the mix will break down the seals in the fuel system. Replacing them is somewhat easy depending on location
Old Jun 28, 2013 | 09:08 AM
M3THTICAL(EF)'s Avatar
Need some info on this too, my stock d16a6 has also been getting crap mileage. Used to average around 30 city driving. Now its around 25. It also bogs,stumbles in the low rpms before it runs good after the 2500 rpm range.
aziatekverse
Honda Civic (2006 - 2015)
25
Aug 11, 2008 08:41 PM
easynowrudeboy
29
Sep 26, 2006 10:15 AM
efrex
Jan 25, 2006 07:06 PM
CRX Si
20
Sep 16, 2004 11:15 PM
RacerBoy
Oct 2, 2002 03:07 PM
