gsr longblock fs w/ extra parts
Old Mar 17, 2010 | 11:25 AM
jasoncrashtech's Avatar
Default gsr longblock fs w/ extra parts
i have a jdm gsr longblock for sale and other parts that i no longer need. i will try to sell as a complete block but i might part everything out depending on offers. the parts are as follows
aem fuel rail (b16a or b18c) -90 obo
aem fuel pressure regulator (b series) -60 obo
holley fuel pressure regulator (b series) -60 obo
str adjustable cam gears for b series vtec cams -100 obo
eagle h beam rods w/arp rod bolts (brand new in box and still bagged) -
arp head studs (used once) -80
LS crank in good shape -best offer
the long block has
gsr cams
flat face s2 valves
dual valve springs
bottom end is stock but the jdm pistons have a higher dome then u.s. pistons
stock intake manifold w/ throttle body
stock exhaust manifold w/ jdm heat shield
there is no water pump or timing belt.
the valve cover is laser cut for gears and the paint is stripped off.
stock injectors, the jdm p72 ecu but no wiring harness.
rear motor mount and motor mount for timing side
motor is not assembled
pic's on request, serious inquires only, cash, possible trade, paypal and so on.
thank you
Old Mar 18, 2010 | 03:10 PM
Default Re: gsr longblock fs w/ extra parts
located in spokane
Old Mar 25, 2010 | 09:02 AM
bmp
jasoncrashtech
Mar 25, 2010 09:01 AM
Mike_S
Southeast (Sales)
26
Aug 26, 2009 03:24 PM
Mike_S
Aug 4, 2009 05:25 PM
turbodegsi
Apr 3, 2007 06:23 PM
SPOON_BeIgHtEeNsEe
Northwest (Sales)
May 9, 2006 12:36 PM
