car starts and dies real quick
its not the main relay i checked
can it be the o2 sensor not being plugged in or cause i am using an si ecu or the map sensor is bad?? would that make my car start and die in a few seconds and not let my car stay on??? any ideas?
it has spark it just starts fine and then dies boggs out and idle drops a few seconds after starting i have no frickin
clue what is wrong
clue what is wrong
if you have a friend around spray carb cleaner in the throttle body while starting.when running keep spraying,if it keeps running then its fuel.thats the easy way i would do it.
