Car is overheating randomly wtf!!
Old Mar 17, 2010 | 05:42 AM
xolk88's Avatar
Default Car is overheating randomly wtf!!
My car just started to randomly overheat out of nowhere. It doesn't do it everytime I drive but mostly on the interstate but it also does it when I idle. Its fine when I turn the heat on but now the heat doesn't even come on everytime I just have to get lucky and hope it does..any suggestions on what to check?
Old Mar 17, 2010 | 05:51 AM
EE_Chris's Avatar
Default Re: Car is overheating randomly wtf!!
Coolant level.
Old Mar 17, 2010 | 05:54 AM
xolk88's Avatar
i just filled the coolant and the radiator fan does come on at higher temps..
Old Mar 17, 2010 | 05:56 AM
EE_Chris's Avatar
Lower radiator hose cold when it overheats?
Old Mar 17, 2010 | 05:58 AM
xolk88's Avatar
i have never checked that hose i know the upper hose is expanding and gets very hot so im planning on changing that today
Old Mar 17, 2010 | 06:00 AM
HondaPartsHero's Avatar
Technical Hero
Thermostat
Old Mar 17, 2010 | 06:03 AM
xolk88's Avatar
I was thinking the thermostat but wouldn't that cause it to overheat every time i drive it?
Old Mar 17, 2010 | 06:19 AM
xolk88's Avatar
and what would cause my heater to work randomly?
Old Mar 17, 2010 | 10:05 AM
EE_Chris's Avatar
If the thermostat were stuck closed, then yes, it'd overheat all the time. When thermostats go bad, sometimes they get stuck in one position (totally open, closed and everything in between) and sometimes they don't open all the way or open in a linear fashion. And when they are stuck closed, they don't allow coolant to circulate through the engine or the heater.
I typically replace the thermostat as part of routine maintenance when doing a timing belt (every 100k miles) so as to avoid this problem.
Old Mar 17, 2010 | 06:20 PM
xolk88's Avatar
ok well i will be replacing the thermostat but why would my heater just randomly not come on?
Old Mar 18, 2010 | 05:18 AM
EE_Chris's Avatar
You get heat because hot coolant is flowing through a small radiator with a fan blowing air across it into your cabin. If hot coolant isn't flowing, you don't get heat.
dbailey
11
Jan 30, 2020 04:27 AM
dlstech
16
Dec 12, 2012 03:04 AM
dsands7
Aug 21, 2012 10:29 PM
d16a9_edcivic
13
Dec 14, 2008 11:50 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
