ls swap obd1??
Old Mar 16, 2010 | 07:08 PM
2000ITR#1207's Avatar
TRIAL USER
Default ls swap obd1??
ok i Know some one's gonna insult me or call me a noob lol. her goes. i have a 90 crx hf dual point obdo. i have a 98 ls that to my understanding obd2 ls is a obd1 just longer for the ls? Also i have both shock tower harneses obd1 integra it might be gsr. can i use harness? and gsr tach? thanks
Old Mar 16, 2010 | 09:59 PM
D16SiHatch's Avatar
Default Re: ls swap obd1??
you can't use any harness but the one that came in the car originally. and you must be confused because a crx hf is not dpfi, it's mpfi.
no idea what you are trying to say by "obd2 ls is a obd1 just longer". the obd2 and obd1 variants are virtually identical. you'll either run it obd0 or obd1, up to you on how you want to do that. if obd1 then you can use the obd2 dizzy because interally its the same as an obd1 unit, just the plugs are different. and you will need an ecu jumper to run an obd1 pr4 or p75. if you want to run it obd0 then you will just need an obd0 distributor and obd0 pr4.
by gsr tach i assume you mean the cluster. you can use it, but you have to convert the cluster plugs to the newer style, and run an electronic vehicle speed sensor.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/cluster-lets-see-them-2443255/
Old Mar 17, 2010 | 10:52 AM
TRIAL USER
sorry for confusing you. my crx had the dpfi so its a dx i guess? the ecu jumper would work fine for my p75, but where harness meets in the engine bay the plug is round from ecu and the motor is the "obd1" square type is there a kit or jumper for that?
Old Mar 17, 2010 | 11:18 AM
4drEF's Avatar
Keyboard Humorist
I think the engine bay plug styles differ between years - 88/89 have one type and 90/91 use a different shape.
Might want to check with the company you bought the jumper from and see if they will exchange it if this is the case.
Old Mar 17, 2010 | 02:25 PM
TRIAL USER
here to make it easy first pic is of the dx wire harness. the second is of ls. the car still has round plug coming from firewall/ecu. how do i make this work? thanks
Old Mar 17, 2010 | 03:07 PM
lunalink's Avatar
^ as previously stated. you MUST use the harness that came with the CAR.
you have to modify you ORIGINAL harness i.e add/extend wires.
take plugs that you need off the LS harness and add them on to your DX harness
Old Mar 17, 2010 | 03:48 PM
TRIAL USER
do you know any one who can help or a link for info on how to... thanks
Old Mar 17, 2010 | 04:08 PM
projekt90ef's Avatar
theres hundreds of threads on this already...prob hundreds on a crx dx-98 integ ls swap alone....in the ef/crx main page you'll see a search option called "search this forum" type "98 ls swap"
Old Mar 17, 2010 | 05:39 PM
4drEF's Avatar
Keyboard Humorist
WOW.
Disregard my post completely.
Not sure what I was reading, but I thought you had a jumper harness that wouldn't plug in.
Old Mar 17, 2010 | 06:24 PM
WHITECOUPE13's Avatar
i think u should burn the bitch
Old Mar 17, 2010 | 07:02 PM
lunalink's Avatar
Old Mar 17, 2010 | 07:29 PM
TRIAL USER
I'm about too! lmao
Old Mar 17, 2010 | 07:37 PM
dont...this is a good thing to do....but you should probably have a friend that knows how to do it with you. dont know anybody, youre better off just selling the motor...
Old Mar 17, 2010 | 07:49 PM
D16SiHatch's Avatar
http://hondaswap.com/swap-articles/d...writeup-49557/
supra-n-civic
Oct 21, 2009 06:05 PM
h22civicek
Jun 16, 2008 09:06 AM
iheartmyef
Mar 26, 2007 01:16 PM
VTECth1s
Jun 7, 2006 05:51 PM
BikeSpike
Apr 10, 2003 10:34 AM
