92-95 obd1 usdm prelude distributor
Does anybody know if I order a USDM 92-95 obd1 h22a distributor will it have the ckp/tdc/cyp sensors in the distributor housing like the JDM version or do the US versions have the sensors on the engine block?
Do you have to drill a hole thru distributor housing to get the internal coil wires out in order to convert to external coil? I don't want to spend $270 on a us version distributor only to find out it doesn't have the sensors and I can't return it due to electrical part !!! Help
VWkila
Aug 8, 2003 03:59 AM
