EG with ls swap throttle cable question
I just did an obd1 Ls swap in my EG and the D series throttle cable has the bracket to close to the end of the cable so it won't mount where it should on the B series manifold. My question here is can I use a cable and bracket for a 99-00 Si also would I only need the throttle cable and bracket for the manifold only or do I also need the one for the gas pedal also.
You should be able to use any B series throttle cable except some GSR years. I ran into some of them being alittle long when I did my LS swap. The b16 cable will work.
Alright thanks what about the brackets and all just the one for the manifold correct or do I need the one for the pedal also and the gasket that goes through the firewall?
Hmm if I remember correctly the pedal bracket should be the same or very close to it. It can be jimmy rigged or you can just go to pull a part at a junk yard and find one to be safe. The throttle is the same pretty much I just threw the cable on never even thought to change it. The gasket in the firewall is good to have but not absolute. I don't have a gasket in my fire wall for the cable. I ran mine through some plastic tubing. SO I dunno exactly if it has an affect on the life of the cable or anyhting.
the parts are cheap enough from the dealer, this situation doesn't warrant a rig job. You can probably gets the parts to do it right from the dealer for about $35, you will be happier in the long run and it will look cleaner
gl
012 16411-P75-000 STAY, THROTTLE WIRE 1995 INTEGRA 9.50 7.13
http://www.hondapartsunlimited.com/i...&submit=submit
010 17910-SR3-L01 WIRE, THROTTLE 1995 INTEGRA 26.53 19.90
http://www.hondapartsunlimited.com/i...stration=PEDAL
gl
Just buy a new 94+ LS throttle cable, I got mine from a dealer for under $20. It fits perfect on the pedal and mounts exactly where you need it to when using the OEM LS bracket on the Intake manifold.
I ordered a B16 cable,brackets and gasket from Honda since it was closer and since Acura said it would take longer to get then Honda i'm picking up the parts tomorrow I hope it works out I'll post pics of before and after thanks for the help.
HondaMechanic24
11
May 4, 2013 05:07 AM
-HONDA-
Aug 22, 2007 11:51 AM
