can't find hole in firewall
i've been looking for the small holes that are supposed to be in my firewall. I know that they're supposed to be covered with a rubber grommet or something, but maybe i'm not looking hard enough? I have a 00 civic si, so could any of guys help me find the location of the hole ? thanks.
Maybe I am missing something but what exactly are you trying to do? Are you trying to run wires from the engine bay, through the firewall and into the cabin? If so, there should be at least one hole below the battery tray and kinda to the right(if your standing in front of car looking at engine). There will be some foam stuff that you will have to push the wire through, then go inside, reach up under the dash and pull it through.
Yeah, there's one directly below the battery tray that has the engine harness going through it. There's another one to the right maybe 6" covered by a rubber grommet... that's what I ran my amp power through.
Look harder, mang. They're in there.
Just push it through, the foam stuff is just on the back side of the carpet. Just push it through as much as you can from the Bay, then go inside via passenger door, reach up under the dash, feel around and pull it through. Then route it from that point where ever you need it.
floyd_rockz
May 3, 2006 06:43 AM
TrikMeister408
Nov 27, 2002 06:27 PM
