d15z1
With VTEC-E, you have 1 intake valve per cylinder closed until the VTEC mechanism engages (somewhere around 2000-3000 RPMs). So with the P28, you're running with those valves closed until VTEC engages at 4500-5500 RPMs. With those valves closed, you're not getting as much air into the engine, but you're still giving it fuel needed for a D16Z6; so you're running rich. You should get the right ECU, or swap the engine.
Carolina Fried Rice
14
Mar 2, 2005 10:23 PM
NatedoggAZ
Jul 31, 2003 05:01 AM
