H-T geeks i need your help.
Old Mar 15, 2010 | 07:42 PM
alx_90ef's Avatar
Default H-T geeks i need your help.
jk about the geek part tho! ^_^
ok guys so i got an dohc zc and a p75 ecu and a td43u dizzy for cheap.
i mean cheap.
ok heres the problem.
THE ****EN DIZZY IS IN PEICES!!! WTFFFF
ok so i need help putting it back together.
does anyone have a diagram for that bitch?!?!?!
helps plz.
thanx in advanced.
Old Mar 15, 2010 | 08:13 PM
alx_90ef's Avatar
Default Re: H-T geeks i need your help.
or any other obd-1 dizzzy!!! plz help!!!
Old Mar 15, 2010 | 09:01 PM
alx_90ef's Avatar
nvm i got it already pretty simple actually.
now i just need to figure out how to covert from the obd-0 connector to obd-2 dizzy connectors
Old Mar 15, 2010 | 09:26 PM
D16SiHatch's Avatar
Old Mar 15, 2010 | 09:29 PM
alx_90ef's Avatar
ok the two white look the same size to me=/
Old Mar 15, 2010 | 09:32 PM
alx_90ef's Avatar
nvm i think i got it.
now how do i run the 4 wire o2 sensor?
Old Mar 15, 2010 | 09:49 PM
D16SiHatch's Avatar
does your ecu jumper not have the wires labeled for which ones go to the o2? if you had a rywire jumper for example it would have a subharness with a wiring extension and plug already in place for the 4 wire o2 sensor.
Blue_ef23
Aug 23, 2014 02:43 PM
10psiLsEf2
Dec 7, 2011 07:20 PM
kilo_da9
Aug 25, 2008 02:00 PM
Ls1 FD3s
Aug 27, 2007 06:44 PM
lCHaCHeel
May 4, 2007 06:53 PM
