dynoed my hybrid eg coupe yesterday
Old Sep 8, 2002 | 05:10 PM
stevel's Avatar
Default dynoed my hybrid eg coupe yesterday
hey all,
dynoed my eg coupe yesterday. it's a '99 b18c1 with AEM intake, R*SR header, carsound 2.5" cat, thermal cat-back and a chipped OBDII ecu, stock internals.
it peaked at 156.5hp and 117.8 tq.
what do you guys think? I don't have a scanner so i can't post my plot but if you have any specific questions about the powerband or the a/f ratio please ask. I have the a/f ratio printed out for each 100 rpm.
s
Old Sep 8, 2002 | 07:37 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: dynoed my hybrid eg coupe yesterday (stevel)
Here's my 1995 b18C1 dyno plot...it was done on Saturday..
KN filter on short ram
DC 4to1 Header
Race cat 2.5
Greddy PE exhaust
stock internals
stock ecu
Skunk2 cam gears at +2 intake +1 exhaust
Old Sep 8, 2002 | 07:41 PM
JD_B18CDX's Avatar
95 B18C1 on my 92 Hatch.
155.3hp and 118TQ
with 45$ intake, greddy exhaust (for coupe adapted to fit Hatch), stock exhaust manifold, stock ecu.
Added.....
skunk2 stage1 cams, DC 4-1 headers,Skunk2 Cam gears +1 intake +1 exhaust, ign timing @ 18 degrees. Fuel pres @ 55 psi.
184.7hp and 132TQ
I know this has nothing to do with HPs but I like the intake growl better when my cams were stock. With the skunk 2 cams, the engine intake growl sounds unrefined.... like the engine is going to blow up. But it never did anything wrong except for the sound. Still running strong up to now.
[Modified by johnd, 11:51 PM 9/8/2002]
Old Sep 9, 2002 | 11:02 AM
stevel's Avatar
Default Re: dynoed my hybrid eg coupe yesterday (johnd)
Added.....
184.7hp and 132TQ
WOW!! Nice numbers! The skunk2 stage 1 cams are gonna be my next mod. I was curious as to the increase they would give me. That's probably a similiar set-up I would have. I was wondering if I should go with a 4-1 header? Still not sure about that. I'm really impressed with the gains you got though! Now I really can't wait to get them. You used a VAFC to tune the a/f and the vtec crossover, right? What is your crossover?
Blue-civic-hybrid, nice numbers too! Looks like I could wring out a few more horsies with some cam gears and a VAFC. Good job!
Thanks for posting your set-ups and numbers. Anybody else??
s
Old Sep 9, 2002 | 01:22 PM
xtrafastcivic's Avatar
smooth vtec crossover...
Old Sep 9, 2002 | 06:47 PM
gsrvx's Avatar
New User
those are good numbers...last dyno run...i hit 161whp/123 tq.
Old Sep 9, 2002 | 07:28 PM
hybrider's Avatar
Default Re: dynoed my hybrid eg coupe yesterday (RK)
i pulled 143 whp, 95 GS-R swap..when completley stock
going back on there this weekend with,
2.25 custom exhaust, aem cai, CM flywheel and clutch, 195-50-15 pirellis w/rota subs, new plugs/wires/fuel filter, and a valve adjustment, and p/s removed
i better see 150+whp
Old Sep 10, 2002 | 04:14 AM
JD_B18CDX's Avatar
Nope, Still stock ECU. There is a big dip in when the vtec kicks in. Feels like the motor is going to bog. But when it reaches 5,500 Rpm, front tires are really fighting for traction.
The skunk2 cam vtec lobe is huge that it dwarfs the GSR vtec lobe.
BTW, on the second run, the cat was replaced with a testpipe.
The guy who helped me tune the car said that the cams have the biggest effect because it directly affects the engine breathing. But in order to get good gains, you have to improve air flow everywhere else as well.
Old Sep 12, 2002 | 08:19 PM
willyboyK20's Avatar
hey all,
s
How did u chip a Obd II ecu?
Old Sep 12, 2002 | 09:34 PM
stevel's Avatar
Default Re: dynoed my hybrid eg coupe yesterday (willyboyD16)
i didn't chip it. They can be chipped similiar to a OBD1 ECU but many people don't do it because the chips alone (for OBD2) are like $100 whereas the OBD1 chips are like $5. So if one goes on you it can get quite expensive. It was chipped by yoshio of Japanese-Automotive i believe. Why the car was converted over to OBD2, I don't know. It seems stupid to me but he must have had some reason.
s
Old Sep 12, 2002 | 10:34 PM
Y2K Si FBP's Avatar
163.5 and 113.6 torque
b18c1 i/h/e skunk manifold...bbk 70mm tb(hurts low torque) vafc, type r flywheel...going back soon with a chipped p28 and jdm dc 4-1..high flow cat..fresh iridiums..hope to hit 170+ on stock cam
TRU_Luck
Nov 25, 2007 06:02 AM
95 honda8
Oct 31, 2007 12:06 PM
delusionracer
Northern California (Sales)
May 1, 2006 11:56 PM
apm
Northwest (Sales)
Nov 18, 2005 01:51 PM
apm
Northwest (Sales)
Jul 26, 2005 09:13 AM
