FS: 93 4dr LX Civic part out! even some free stuff =)
My old 93 beater civic is currently being turned into a track car.. so the old motor is out.. it was a bit of a Frankenstein but it worked.. i picked up the car for CHEAP with a blown motor.. i located a free d15b2 block and used the old d15b7 head and auto trans.. she ran for a while before the valves started leaking.. so no compression = no run =( I had the head rebuilt.. complete with new guides, seals and valve job.. I am asking $200 for the head.. which is a little less that what i paid to have it reworked.. but will entertain other offers.. The head is complete with valve cover, manifold, tb, injectors, fuel rail, and distributor.. I put prob 200 miles on head before a crank bolt mishap went down...
Everything other than the head is make an offer.. willing to get rid of this stuff cheap!
All 4 door windows
the dash
engine mounts
automatic pedal assembly
stock suspension
PS pump
D series flywheel
entire srs unit.. wiring.. and sensors..
Stock automatic radiator
There is more laying around the garage right now, I just cant think of it all.. if you need something you dont see please ask! I just might have it!!
[THE FREE PART]
the engine block and auto trans i am giving away to whoever wants to come and get it! other than the fact that the crank bolt broke off in the crank the engine runs.. and surprisingly enough doesnt smoke.. if you can somehow get whats left of the crank bolt out you can stick the pulley back on and be good to go.. or find a crank and swap it out..
I will hold onto the head until someone needs it.. but im only going to keep that engine block and auto trans around for a few more weeks before i toss it. Oh yea other than a slight jerk when shifting from time to time.. the transmission is still in working order!
If you would like you can follow the lemon build on facebook! http://www.facebook.com/profile.php?...00000833422839
All 4 door windows
the dash
engine mounts
stock suspension
PS pump
D series flywheel
[THE FREE PART]
Headman
15
Jul 19, 2013 12:37 PM
