Smallest size wheel for spare on 99 civic si
I have a 13in spare wheel, 14in spare wheel, and a 13in wheel from an older civic maybe an ef. Will the 13in ef wheel clear the oem 1999 civic si disk breaks? Or will only the 14" spare work?
only had time to do it on the rear. 14" cleared no problem 13" would turn but rubbed on the dust protector. So if that was shaved down it would work no problem.
if im not wrong the ex si have the same brake setup so the 14 in is the smallest you can go if i remember correctly
