Swap or not? F22B2 94 Accord
Old Mar 15, 2010 | 01:27 PM
dagle's Avatar
Default Swap or not? F22B2 94 Accord
found mud in the oil pan guess the dbag that sold me this car really needed to get one over to sell it. drives fine as-is, but i know it's running on borrowed time. Sipping coolant at a rate of about half a quart a week.
Now H-Ter's I ask, what would you do? Put in an unknown but supposedly running swap from a wrecked car, or would you replace the headgasket and gamble with the chance of a warped deck?
Machining is out of the question because I don't have the time to disassemble the shortblock to get it to the machinist and go through all the steps when I could just replace the motor and sell it with a decently running motor from a different car.
and finally, DAMNIT WHY DID I BUY AN AUTO if it was 5spd I could drop my extra H22 + P13 in.. I have all the god damn parts for the swap.
Old Mar 15, 2010 | 01:46 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Swap or not? F22B2 94 Accord
Why not mate the H22 to the automatic transmission?
Personally I'd think if you seafoamed the motor, changed the headgasket, changed the coolant, changed the oil, etc you could keep the car as is with current motor.
Old Mar 15, 2010 | 02:50 PM
dagle's Avatar
because using an h22 is a waste of a nice motor (in my opinion of course). I guess the question is mainly from a time-constrained stand point where I can't have a car on jack stands for an extended period of time. So here are the options that I currently see:
A) Take the head off, measure for flatness with precision straight edge, and put a new headgasket on and run it from there. The problem is that if the block is warped, it'll be a painful process to get it out and get it machined.
B)Get a dirtcheap F22B2 and drop it in, probably a 1-2 day affair.
basically with option A, it's a gamble of spending a mere 60 or so dollars on a HG or it could spike up easily to 3-400$ for machining and other parts while I'm in there. But with option B I would be spending 250$ flat rate for a running motor (most likely, but the off chance it has a problem can occur as well). So I don't know which gamble would be the safer gamble.
Old Mar 16, 2010 | 03:29 AM
f22a1 ftw's Avatar
id say go with b sounds like a better bet imo but what do i know im legally retarded
Old Mar 16, 2010 | 05:25 PM
dagle's Avatar
you're lucky, I get parking tickets for the meter . we'll see what the next week has in store for me. might just make it a project over a couple of weekends. just means I have to get my god damn s2000 road-worthy sooner
josh's_accord
May 13, 2008 06:02 PM
keraann
Oct 17, 2007 05:42 PM
213374U
Nov 19, 2006 05:05 PM
jdmeg9
Jul 29, 2005 05:53 PM
toughlou
May 21, 2005 02:32 PM
