ek climate control?
Old Mar 15, 2010 | 12:21 PM
o_0's Avatar
o_0
Default ek climate control?
I have a 2000 Ek hatch. For some reason when i try to turn on the cold/hot air, it wont blow out air unless I turn the **** all the way to high. Other than that, it wont turn on. I tried switching the climate control **** and buttons and still does the same. Has anyone had this problem? What can I do to fix this?
Old Mar 15, 2010 | 01:52 PM
r1whore's Avatar
Default Re: ek climate control?
99-00 is all electronic controlled. sounds like the controlling arm on the valve is either not attached or has too much slack. have someone inside your car turn it hot then cold then hot and you will see this arm behind the throttle boddy on the firewall move make sure its on the latch.
Old Mar 16, 2010 | 03:40 AM
o_0's Avatar
o_0
I'm not having problem with the temp. of the air. I'm having problem with controlling the speed of the air. I hate having to blast the air all the time when i wanna turn on the air. I should have made it clear that it was the speed of the air i wanted to fix.
Old Mar 16, 2010 | 10:34 PM
o_0's Avatar
o_0
bump
Old Mar 16, 2010 | 10:38 PM
Deetz's Avatar
Crazy Honda Guy
Yes, your problem is an easy fix....it's the heater transistor. Common issue when cars get older
Old Mar 17, 2010 | 01:18 AM
devarian's Avatar
or could be the blower motor. but check the transistor first
Old Mar 17, 2010 | 11:43 AM
o_0's Avatar
o_0
where is the transitor located at on the ek? also what does it look like?
Old Mar 17, 2010 | 11:50 AM
98civdx's Avatar
Master Detailer
if it what im thinking it is, open glove box, and get it to come all the way down and it should a little to the right.
https://honda-tech.com/forums/tech-misc-15/blower-motors-works-speeds-3-4-but-not-1-2-fix-how-2082345/
Old Mar 17, 2010 | 12:08 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Isn't that a blower motor resistor, rather than transistor? Either way, that is your problem.
Old Mar 17, 2010 | 02:25 PM
98civdx's Avatar
Master Detailer
thats what im not sure about, maybe he just called it something differnt??
Old Mar 17, 2010 | 03:41 PM
o_0's Avatar
o_0
coo thanks alot guys!
Old Mar 17, 2010 | 05:45 PM
Deetz's Avatar
Crazy Honda Guy
I am a parts man for Honda, i use the proper terminology.
79330-S10-A42 Part#5 TRANSISTOR ASSY., POWER
itr1448
Feb 18, 2010 09:31 PM
xKAMILxEK
Dec 3, 2009 08:42 PM
wblakes
Jun 6, 2004 11:18 AM
W.O.P.
Apr 14, 2004 04:44 PM
