Wat To Do??
Old Mar 15, 2010 | 10:08 AM
toolbox21's Avatar
Default Wat To Do??
88 HF "B16A2" Converted To OBD1 Via Ry-Wire Using A Chipped P28 ECU With A Base Map. MY Car Wont Start It Just Cranks And Cranks, ECU Is Good, Main-Relay Good, All Grounds Are Good And Additional Grounds, Got Plenty Of Gas In The Tank, Im Getting Spark Thats Not A Problem, When I Turn The Key To #2, I Can Hear The Fuel Pump Kick ON/OFF And The Injectors Are Priming, I'm Getting Fuel To The Rail But None Is Coming Out Of The Regulator I Did Not Know If Fuel Only Comes Out When It Running But That Could Be A Problem I Just Need Some Advise, Also I Replaced Both Fuse Boxes For The Hell Of It, And New Resistor Box, Any Ideas??????????
Old Mar 15, 2010 | 10:26 AM
lunalink's Avatar
Default Re: Wat To Do??
its the exact same setup i have on my CRX lol.what injectors are you using? post pics of your setup. is all your wiring connected good? any loose ends?
Old Mar 15, 2010 | 10:42 AM
toolbox21's Avatar
the same obd0 injectors ive been using, see i had the same saetup in a 91 hf and i got a 88 hf shell and swapped everything including harness so its really weird the only code im throwing is vtec cuz i dont got it wired up just yet
Old Mar 15, 2010 | 12:37 PM
lunalink's Avatar
did you swap both engine harness and under dash harness?
Old Mar 15, 2010 | 01:43 PM
toolbox21's Avatar
yeah all the wiring and motor and everything is swapped over, see i bought the car with a wire-tuck that was more like a wire f*ck, so i just changed everything
Old Mar 15, 2010 | 01:57 PM
lunalink's Avatar
mhm..o.k well thats settled.
cables, check your coil.
Old Mar 16, 2010 | 05:31 AM
toolbox21's Avatar
yeah ill try that again i mean it worth a shot right lol
Old Mar 16, 2010 | 07:16 AM
lunalink's Avatar
if you can post a vid of it cranking. because it sounds like if its going to be something small ( hopefully)
Old Mar 16, 2010 | 07:37 AM
toolbox21's Avatar
ok ill try to get one up
MrHopper
25
Apr 9, 2011 02:56 AM
Gizz-R
May 20, 2010 07:21 PM
ef-hatchcrap
Feb 11, 2010 11:49 AM
cavakilla
Mar 22, 2004 05:59 PM
Iceycrx
10
Jan 7, 2003 11:55 AM
