whats the difference between aem sohc&dohc intakes?
i've been checking around and there is almost $100 differnce in price
for the 94 delsol sohc and 94 delsol dohc.
i'm just wondering whats the size differnce? 2.5"?2.7" or 3"?
i have a b16 in my eh2, which intake fits my car? i've used the search but didn't get much info
thanks!
thanks!
give these guys a call..i dont see that much a difference in pricing..atleast not the $100 differrence http://www.modacar.com
thanks!
thanks!
So the dohc intake tubes are larger than the sohc ones? I mean theyre pretty much the same size as far as installing goes but if the pipe is larger, more airflow, more hp right?
Cosworth, whats up, near ellsworth here. You ever get any work done at the honda dealership off 49?
[Modified by Dark_Sol, 11:27 PM 9/8/2002]
[Modified by Dark_Sol, 11:29 PM 9/8/2002]
you can fit a sohc intake on a dohc motor depending on the direction the TB points.
this is done by squeezing the rubber over the TB (that didnt sound too good
anyways, although it can be done.. why do it? putting a smaller intake on a bigger TB defeats the whole purpose of a bigger TB. thats like getting a header with a 2.5" collector and putting a 1" cat and b-pipe on it.
).anyways, although it can be done.. why do it? putting a smaller intake on a bigger TB defeats the whole purpose of a bigger TB. thats like getting a header with a 2.5" collector and putting a 1" cat and b-pipe on it.
thanks for the info guyz
but i've also read some post that they had the 99-00 si intakes with there b16 swap in the eg/eh but had minor fitment issues. Which one would be the perfect fit? should i just get the one for my car originally?
Da D0n
Feb 24, 2008 02:31 PM
ce
Aug 19, 2002 01:35 AM
