Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Suspension Questions
Old Mar 14, 2010 | 01:21 AM
bopbop93030's Avatar
Default Suspension Questions
08 Civic EX Sedan
Do they have Sway bars? If not, can you put one in there?
How hard it is to replace the springs on this model is there a right up and lastly do they have camber adjustment.
I know I just need to set the toe to 0, but I hate that look when the camber is not set correctly.
Thanks!
Old Mar 14, 2010 | 09:52 AM
K5^'s Avatar
K5^
Brand New
Default Re: Suspension Questions
Post any/all suspension questions here:
https://honda-tech.com/forums/honda-civic-2006-2015-79/%2A%2A%2Aofficial-8g-suspension-thread%2A%2A%2A-2737902/
But to answer your question, FG1/FA1's have front and rear antiroll bars (w/the exception of the DX model, only the front is equipped). Non-Si's have 25.4 mm / 11.0 mm (F/R). Si's have 28 mm (solid) / 17 mm.
You can interchange them quite easily. Some of the first mods people do with non-si's is to swap out their antiroll bars to si ones.
As for springs, the fronts require more work than the rears do.
Ohmega
Suspension & Brakes
May 5, 2015 04:46 PM
TypeRBoy
Dec 13, 2008 08:30 PM
project 2two9
May 13, 2006 01:44 AM
turboman
Suspension & Brakes
Apr 26, 2005 06:28 PM
Stunna BEN
85
May 14, 2004 11:50 AM
