Where do the parking light wires come from under the hood?
Old Sep 8, 2002 | 02:51 PM
FusionITR's Avatar
Default Where do the parking light wires come from under the hood?
where do they come from? i cant even find mines
Old Sep 8, 2002 | 02:58 PM
Mike M's Avatar
Founding Member
Default Re: Where do the parking light wires come from under the hood? (FusionITR)
Pop off the Turn signal in the bumper and tap the wire on the bulb on the outer section of the lense. Its either a Green or red wire.
Old Sep 8, 2002 | 03:05 PM
FusionITR's Avatar
Default Re: Where do the parking light wires come from under the hood? (Mike M.)
jdm front
Old Sep 8, 2002 | 03:11 PM
Mike M's Avatar
Founding Member
Are you trying to hook up your lights?
If So, Do a Search for Archived and recent posts by me in the ITR Forum about JDM Fronts - I've covered it Many times.
Or do you just need to tap a parking light wire?
If So, Pull the Fender well liner back and the bulb is accessable along with the socket and wires.
Old Sep 8, 2002 | 03:14 PM
FusionITR's Avatar
not im not trying to hook up my lights, im trying to see if if the wires are touching any ground because my passenger side tail lights arent working and im trying to determine the problem
Old Sep 9, 2002 | 02:45 PM
FusionITR's Avatar
ttt
Old Sep 9, 2002 | 07:24 PM
ITR#132's Avatar
Pull out your turn signals and check the connection there.
parking light wire on Hondas has been red with a black stripe for as long as I can remember.
If you want to check the wiring, you will need to pull the bumper for easy access.
eg-6 life
Oct 4, 2010 09:57 PM
kim_2_da_chee
Jun 23, 2005 09:32 AM
jemdogs
Oct 4, 2004 11:44 PM
everafter
Jan 4, 2004 07:23 PM
slammmedintegra
Nov 20, 2002 06:05 PM
