96 accord ex not revving past 4500 on Drive
Old Mar 13, 2010 | 06:55 PM
ef9wpb's Avatar
Default 96 accord ex not revving past 4500 on Drive
Hellow honda-techers,
I have an issue with my accord that I have not been able to figure out. If the car is cold, I start it and it revs fine for a block or so, once it gets warm it will not rev past 4500rpm. Does any one have experienced and fixed something like this? Please help!
What have I done:
Full tune up: Fuel filter, yes I did!, spark plugs and wires, distributor cap and rotor, PCV valve.
Check Engine Light?
I was getting 67 (cat), 71 (misfire), 72 (misfire) but after the tune-up today, I cleared them and have not came back. No other lights though.
Theories:
1) It is the distributor
2) It is the ECU
Theory challenge:
This is my first accord so I do not have any spare parts to play around. Tried to change the ECU but a Civic one wont work (one plug has a little difference).
Also, opened up the distributor but nothing works from a civic one
Let me thank you all in advance for looking out!
Old Mar 15, 2010 | 01:28 PM
ef9wpb's Avatar
Default Re: 96 accord ex not revving past 4500 on Drive
Any body out there? I am sure I am not the only one that has had this issue, thanks again
Old Mar 15, 2010 | 04:24 PM
jmjohnson128's Avatar
how does it run up to 4500?
have you checked egr to see if plunger still moves?
Old Mar 15, 2010 | 05:41 PM
davey5300's Avatar
try cleaning up the VTEC solenoid screen
Old Mar 18, 2010 | 08:18 PM
ef9wpb's Avatar
Humm, I have not done that but will try
ef9wpb's Avatar
Not sure about that but will try, thanks
Old Mar 18, 2010 | 08:20 PM
ef9wpb's Avatar
Update:
The car is misfiring again, sometimes, no code yet. It happens only when I start it and goes away quickly. I smell the unburned gas, can someone sell me a damm distributor so I can try that?
bluelights81
Mar 18, 2014 01:16 PM
patelmd
Jun 17, 2012 12:26 PM
Accord5Gen
Dec 19, 2009 09:26 AM
madness_integra
Jul 13, 2004 06:03 AM
