fully built ls vtec
So here is my build and what parts I have gathered so far. the LS/VTEC will be going into a 89 EF Hatch.
2000 B18B Block
Internals
Weisco Pistons/Rings/Wristpins
Bore 81.5mm
Dome +5cc
Comp Ht.: 1.1855
Scat Rods & ARP Rod Bolts
Length/.827 Wrist Pin/.935
Big End Weight 349
Small End Weight 149
Eagle 4340 Forged LS Crank
1990 JDM B16 Head
Currently Has GSR Cams Dual Valvesprings
I will be upgrading these I could use some input for cams and valvetrain I have been considering Crower Stage 3 or maybe Buddy Club Spec V?
Fuel System:
SARD Fuel Rail
BDL Industries FPR
DSM Bluetop 440cc Injectors
Walbro 255 Fuelpump
YS1 LSD GSR Cable tranny
7.5 Lb Fidanza Flywheel
Hasport Shiftlinkage
Polyurethane Driver/Tranny Mounts
Solid Rear Mount
Misc Parts:
Blox Magnetic Drain Plugs
AC Camseal
CTR Crankshaft Pulley
I still have a long way to go on the build but let me know what you think!
2000 B18B Block
Internals
Bore 81.5mm
Dome +5cc
Comp Ht.: 1.1855
Big End Weight 349
1990 JDM B16 Head
Fuel System:
SARD Fuel Rail
BDL Industries FPR
Walbro 255 Fuelpump
Solid Rear Mount
Misc Parts:
AC Camseal
[QUOTE=
1990 JDM B16 Head
[/QUOTE]
supertech is good price and good quality.
1990 JDM B16 Head
[/QUOTE]
I'v heard good things about them. I kinda thinking of just matching the valvetrain with the cams buddy club and crower make good valves/springs/retainers right?
Yeah its gonna be tracked, driven only on nice weekends rarely and to meets. I have a del sol as my daily. I have an OBD0 to 1 jumper and a chipped p28 on crome.
Im going to be buying a edelbrock performer x intake manifold and toda gsr timing belt this thursday. Could use some imput on what size throttle body to run with my setup I will be purchasing this soon but need to do some research before i do.
I think Buddy Club Spec V cams are too big for your setup. A buddy of mine had Spec V on his 2.0 build. Im thinking S2S2 or S2S3 cams would be good enough.
g2lsvtec
12
May 13, 2006 04:02 PM
the.hamburglar
20
Apr 4, 2006 07:52 AM
