Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
clutch MC fluid?
Old Mar 13, 2010 | 11:01 AM
maxogsr's Avatar
Default clutch MC fluid?
I know it's brake fluid that goes inside the clutch MC but can I put any kind?
I was thinking about Motul RBF660... I got half a can left from my brake job... Or should I stick with dot3 or 4
Old Mar 13, 2010 | 12:08 PM
unusual71's Avatar
Default Re: clutch MC fluid?
the clutch system doesnt see the temps that the brake system does, i bet the clutch is much less sensitive to type of fluid used than your brakes are.
Old Mar 13, 2010 | 02:13 PM
Atmosfear's Avatar
^^Agreed. It would be a total waste of RBF. Considering its about $20 for .5 liters, just save it for the next brake job.
Old Mar 13, 2010 | 05:11 PM
bokals's Avatar
DOT 3 will be fine.
Old Mar 18, 2010 | 10:36 PM
CONEV8R's Avatar
Yep. Regular ole cheapo DOT3 is fine for the Clutch Hydro system. I personally use the Castrol GT LMA brake fluid, simply because of the high-humidity area in which I live, and the low moisture absorption properties of the fluid. It's probably a bit overkill, but it's only $.79 more per bottle than the cheap stuff.
Old Mar 19, 2010 | 02:31 PM
The Destroyer's Avatar
Just curious after reading this. Does viscosity differ between brands and dot levels?
Old Mar 29, 2010 | 06:43 AM
JETTO's Avatar
TRIAL USER
i guess viscosity between DOT3 and DOT 4 are alike. but the heat rating of the DOT 4 is much higher than DOT 3. These fluids do wear out as they easily attract moisture. so its important to change these fluids as often as you change your oil. they do get contimated in the brake and clutch hydraulic system.
globy123
Sep 27, 2009 05:32 PM
stackz
Nov 26, 2007 11:32 AM
ragejed
Sep 12, 2002 10:59 PM
magic hat #9
Aug 23, 2002 09:21 AM
