list your ls/vtec set up
Under construction but..
B18A block
B18B crank
B18B rods
PCT (B16B) pistons .25 over
Clevite main bearings
Clevite H series rod bearing
B16A2 head port&polished
Stock valves
PCT springs and retainers
PCT cams
Buddy Club gears
B16A2 trans
370cc injectors
AEM fuel rail
AEM FPR
ITB's
Custom headers
2.5" exhaust/ no cat
Crome
Redline @ 7800 in a 91 Si
Track only car
B18A block
B18B crank
B18B rods
Stock valves
PCT cams
Buddy Club gears
B16A2 trans
370cc injectors
AEM fuel rail
AEM FPR
ITB's
Custom headers
Crome
Track only car
old setup 3 years ago............
head
gsr
supertech valve springs and retainers
jun II cams
jg intake manifold
jg cam gears
jg throttle body 68mm
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
gsr main center caps
fuel managment
crome
rc 320cc
255lph walbro fuel pump
tranny
b16
all stock
header
dtr
4-2-1
now i have a
setup
head
b16 dtr ported
port flow valve springs and retainers
sk2 stg3 cams
jg intake manifold
jg cam gears
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
fuel managment
hondata s200
rc 750cc
90si fuel pump
dtm headers
http://img112.imageshack.us/img112/4775/dsc002815bt.jpg
head
gsr
jun II cams
jg intake manifold
jg cam gears
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
fuel managment
crome
rc 320cc
tranny
b16
all stock
header
dtr
4-2-1
now i have a
setup
head
b16 dtr ported
sk2 stg3 cams
jg intake manifold
jg cam gears
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
fuel managment
hondata s200
rc 750cc
90si fuel pump
dtm headers
b16 head
gsr cams
s2 cg
s2 im
hondata img
aem fpr
310 type s injectors
b18b block .20 over
stock rod
stock crank
.20 over nippon ls piston
acl bearings
arp rod and head bolt
gsr oil pump
gsr wp
gsr t-belt
gsr tranny
8lb fidanza whell
stage 2 fidanza clutch
type r header.
car ran 14.flat @101
ran 12.7@108 with 75 shots
car still running till now since rebuild. 3 years ago.
gsr cams
s2 cg
s2 im
hondata img
aem fpr
b18b block .20 over
stock rod
stock crank
acl bearings
gsr oil pump
gsr wp
gsr t-belt
gsr tranny
8lb fidanza whell
type r header.
in process of building
b18b block
b18c1 crankshaft
b18c1 rods
p72 pistons
b18c oil pump
2 layer head gasket
arp head studs
gsr water pump and timeing belt
diy lsv oil line made with solid transmission cooling line direct tap after oil filter on side of block
b16a2 head port polished
new style lma's
toda spec D cam shafts and springs
b17a1 straight intake manifold
compressions around 10.50:1 head gasket away from finishing motor
b18b block
b18c1 crankshaft
b18c1 rods
p72 pistons
b18c oil pump
2 layer head gasket
arp head studs
new style lma's
b18b block
b18c1 crankshaft
b18c1 rods
p72 pistons
b18c oil pump
2 layer head gasket
arp head studs
new style lma's
b18b block
b18c1 crankshaft
b18c1 rods
p72 pistons
b18c oil pump
2 layer head gasket
arp head studs
new style lma's
mine:
b18b1
p30 pistons
LS rods
all requisite arp hardware
gsr head with hot street port job from cccylinderheads
Pro1's
twm 50mm itb's
just sold my anr header
made 203/140 last year, hoping for 210+ this year. 1/4 mile = slow, since i cant drive
the sweet part is the usdm gsr trans with mfactory 4.9 FD and 3.07 first gear
been running for 3 or 4 summers now, almost 5k miles of abuse.
just got mine recently, plan to have to have it dynoed next month and then take it to the track this summer, looking for low 14s on street tires. Plan to go direct port 75 shot at some point too instead of upgrading cams then I'll shoot for 12's on nt555r's
b18b block
ctr pistons 81mm
ls rods
arp rod bolts
arp head bolts
gsr oil and water pump
stock b16 head with b16 springs
gsr cams
itr manifold
68mm throttle body
short ram intake with BPI velocity stack
hytech replica header with mandrel 2.5 exhaust
10lb flywheel and stage 2 full face clutch
ls tranny (I actually like this so don't hate, hoping to build a gsr tranny with lsd though)
all smog legal (bar'd for b series) in a eg hatch
b18b block
ctr pistons 81mm
ls rods
arp rod bolts
arp head bolts
gsr cams
itr manifold
68mm throttle body
I requested a short story for a title.
setting on my stand waiting to go in
b18b block
b16 head
Gsr Cams
Full Eagle rotating assembly
ARP main and head bolts
type R oil pump
blockguard
Darton sleeves
skunk2 intake manifold
titanium valves and retainers
eagle ls vtec conversion kit
fidanza lightwieght flywheel
6puck sprung clutch
ls tranny.
b18b block
b16 head
Gsr Cams
type R oil pump
blockguard
Darton sleeves
6puck sprung clutch
ls tranny.
rev-speed
87
Dec 1, 2007 03:55 PM
awdriscol4
Dec 30, 2004 11:16 PM
GodFather of Boost
Aug 17, 2004 08:04 AM
