CALLING ALL H22 CB7'S!!!
Old Mar 12, 2010 | 02:00 PM
$Tweezy's Avatar
Default CALLING ALL H22 CB7'S!!!
hey hey i finally got around to ripping my trans out to install my new clutch and find out if the trans itself is shot not just the linkage or anything... i think i have oil on the friction surfaces...NEWHOOOO
yea ok so it all ready to go and when i was pryin away and tryin to pound the input shaft back out so i could drop it, it seems like the h22 trans is a tad longer and seems to be pinching against the fender under the trans mount, i have a jack with a a 2x4 under the motor, and the trans...im just wondering if anyone else ran into this problem or i should try taking it out through the top... i drilled and tapped the 3 holes to move the studs to use the same bracket on the trans
Old Mar 15, 2010 | 07:19 AM
jhondayang's Avatar
Default Re: CALLING ALL H22 CB7'S!!!
u need to tilt the engine more. basically take out your front mount bolt along with your trans mount mount.
accord2civic2prelude
Feb 4, 2012 06:38 PM
Laskowski
Mar 11, 2011 03:10 PM
fastwanabe
Feb 7, 2007 08:31 PM
bubblehead
Aug 14, 2006 09:55 PM
