wont start...
Old Mar 12, 2010 | 01:36 PM
vteckills40r's Avatar
Default wont start...
so my car had a startin problem sence i got ... i replace the ignition switch and a hole new key with ignition.. startd great . i replaced it a wekk ago... now i turn key and u hear a solinoid click under the dash ..the starter was testd great and ignition switch was brand new.. also i been goin out to my car and the clutch pedal feels like nothin... i bleed it yesterday and now its fine but it looks likes somthings leekin off where the clutch goes in the firewall??? help thanks
Old Mar 12, 2010 | 02:06 PM
lilo_goki's Avatar
Default Re: wont start...
U mean ur clutchmaster cylinder? That might be leaking. Check to see if that's the problem. Does the car crank.
Old Mar 12, 2010 | 03:41 PM
SOHCNightmare's Avatar
If the car does not crank at all. Check and clean your transmission ground with a wire brush. Then if you have the means, check the resistance from the transmission case to the battery neg (blk) pole.
Old Mar 13, 2010 | 07:17 PM
no it dont crank at all. how hard is the clutchmaster cylinder to change ands whats involved with it...
kris9
10
May 27, 2013 03:35 PM
ganjasnack
Apr 2, 2011 11:26 AM
ftrms
15
Dec 22, 2010 04:05 PM
vteckills40r
Mar 13, 2010 11:21 PM
KyleVA
Sep 6, 2006 03:13 AM
