anyone here port their own intake manifold?
I'm not talking about port matching, I'm talking about cutting it open and smoothing the runners, opening the runners up a little at the opening and making a nice/smooth taper, cleaning it up internally, nothing too drastic, and then welding it back together.
I have done mild port work before on fords and don't intend to hog this thing out.
has anyone done this? anyone care to guess how much a mild port job would be worth on a itr intake manifold on a ls vtec with some mild cams?
if anyone has pics that would be appreciated too!
anyone have any dyno sheets or anything? how about some pics for the noob?!
also, what tool are you talking about that gets up in the runners? you mean like a flexi shaft or do you mean just using a super long bit to reach up in there. Would certainly be best if I didn't have to cut this thing open....
http://images.google.com/imgres?imgu...26tbs%3Disch:1
its pretty easy to do but you need a long shank for the cartridge rolls, it takes a lot of time though theres a lot of material
Cutting an aluminum intake open then welding it back together is quite an intense aproach to smoothing out your intake. The long shank grinding bits & alot of patience is prob. the best route. Im not questioning your welding ability but you might aswell fab up a sheetmetal piece it would prob be easier to get right. & you wouldnt risk ruining an intake . Just my .02
I ported mine about a year ago. I don't claim to be a professional. I just enjoy tinkering with stuff.
I cut open the top of the plenum and then opened up the plenum to runner area.
I used a flapper wheel and a dremel. Make sure you use a mask, the last thing you want it to breath in aluminum particles.
When i was done i had my brother weld the top on, and then we bored the TB opening to 68mm. Originally i cut the runners but that is unnecessary if you cut open the top as you can get to the top of runners through the open plenum area.
Here is a pic of the flapper wheel. They make 80 and 120 grit.
As was pointed out, the injectors are after most of the runner. You are probably thinking about promoting laminar flow by establishing a boundary layer. I generally finish the runners to an 80-120 grit finish instead of a true polish for this reason.
AWESOME guys, thanks for the pics and help.
MAR: is that a before and after dyno test? looks like pretty much 1-2hp gains?
I will be just putting this Type R manifold I got on my motor with the 68mm tb for now but then I plan to get some mild cams and spray a 50-75 shot on it by the end of the year and I'll port the manifold when I pull it off to plumb the direct port nitrous. I'll be sure to post pics though, that is awesome everyone is so cool to share here.
This thread inspired me to cut open my b18a intake manifold, I will be porting soon. I didn't realise how thin the metal is! I already see bad casting marks inbetween the runners and a bunch of lumps I can grind.
NICE. great pics, I think I'll probably end up cutting mine open though so that I can taper the runners and clean up the entry of the runners to the ports.
Anyone think a well done, home ported B16 intake manifold would put up similar numbers to an itr or blox im?
spoonlongblock
Honda Civic (2006 - 2015)
Nov 1, 2006 06:01 PM
H series FTMFW!!!
