build H23 head and crower cams for sale
i have an h23 head that been ported and polished it has supertech valves .5 mm oversized supertech bronce guides and crower spring,retainer kit part#84177 this head only has 1000 miles sisce it was rebuild i spend $1000 rebuilding this head
H23 head $600
also have Crower cams part#62481t-2 i'm saling the cams with adjustable cam gears for $350
H23 head $600
Will you take a trade for the cams? I have a set of 87mm JE forged pistons that cost me $800+new. They are in good shape. They are designed to run a h23 crank, h22 rods and give you an 8.5:1 compression ratio. This way you can rev higher due to the better rod/stroke ratio. Here are some pics.
