91 Si Brake issues
Old Mar 11, 2010 | 08:00 PM
JDM91Si's Avatar
TRIAL USER
Default 91 Si Brake issues
Just bought a 91 civic hatch Si, 161k, its got brake issues. the brake lights come on but dont light up when the pedal is pressed. also when the pedal is press theres not much compression, but all the way down only 1 brake only grabs and it locks up. any ideas.
Old Mar 11, 2010 | 08:16 PM
EL Vap133's Avatar
Default Re: 91 Si Brake issues
Do you have enough brake fluid?
Old Mar 11, 2010 | 08:17 PM
JDM91Si's Avatar
TRIAL USER
yeah. and pumped them after i filled it up
Old Mar 11, 2010 | 08:43 PM
SiRJoEy's Avatar
So pedal goes to the floor and when pressed brakes lock up?? How did you pump it?? Brake lights stay on until pedal pressed than they dont work?
dont really understand question
Old Mar 11, 2010 | 11:02 PM
hatchet_honda's Avatar
how are you testing the brake lights if they dont work when the brakes are pressed? aand you have no brake pressure but one wheel locks up? whaa?
Old Mar 12, 2010 | 03:35 AM
hibrydef's Avatar
Ok. I get it. Don't worry you explained it well. Brake lights first, and i am assuming that you atleast pulled the brake lights bulbs out to make sure they are good. When you look at the lack of them there should be two little shiny dots not just one, if they have just one, replace and that is most likely the case. Check your fuses under the dash. Then make sure the little thinga mabober that attaches to the brake pedal to send an electric signal to the brake lights appears to be working. Do that and see what happens, ..... As for the brakes. Which one locks up and can you use the e-brake to make the rear brakes grab simultaneously. This will tell you a couple things. If the rear brakes lock up simultaneously as you yank the e brake then there is nothing physically wrong with atleast the rear brakes. The next thing you should do is bleed your brakes all around, not because you have to, because you should! It's a 19 year old car that you know nothing about (as in that particualar car) and the only thing that keeps you from dying isn't working right. That also may solve your problem. If all fails let me know exactly how it went and just to make sure you know, bleed the brakes from furthest point away from the master cylinder to the closest, making sure to always have brake fluid in the master cylinder.
cavie
Suspension & Brakes
Oct 3, 2008 12:09 PM
dungsta
Dec 2, 2005 07:52 PM
Duster
Jun 4, 2005 02:30 PM
mr. carpenter
Mar 13, 2005 05:14 PM
slowassR
Sep 3, 2003 08:43 AM
