wiring help-ECU pin for eng head temp sensor
I need to rewire the temperature sensor in the head (the one just under the distributor). I'm not really sure which pin to connect to at the ECU. One wire is grn/wht which is the ECU-ground wire. The other is red/wht. There are at least 3 red/wht wires among my ECU plugs. I need to know which position on the plug is the correct spot for this sensor to be wired to.
Acc3l3ratoR
May 1, 2019 07:41 PM
