sohc help
Old Mar 11, 2010 | 01:56 PM
lilcrxx's Avatar
TRIAL USER
Default sohc help
hi everyone my name is chris and im from St. Paul Minnesota. i just picked up a 1990 crx. so my plans are to build it for high compression but from what i have been reading i am confused about what pistons to go with. some people say that if i run p29 pistons that the valves will hit by the way i for got to say its a d16z6. my plans are to run the crower stage 2 cam and the p29 pistons. so if someone could please help me
i did try search but i kept getting throw around on what i actually have to do
Old Mar 11, 2010 | 10:17 PM
lilcrxx's Avatar
TRIAL USER
Default Re: sohc help
anyone???
Old Mar 12, 2010 | 06:28 AM
SpadedEK's Avatar
i believe that setup is fine, with no clearance issues. or so i have read, clay mold it just to make sure
Old Mar 12, 2010 | 06:43 AM
Top Ramen's Avatar
As a newbie, one of the the best ways for you to sort this out is to go through the D series dyno threads and build threads (there are several) and see what has worked for other people. That way, you can get a pretty good idea of what your build should look like, given your budget and power goals.
Best of luck with your project.
Ej2kidd
Oct 12, 2014 01:03 AM
ej1_Łopez
18
Apr 9, 2012 08:04 PM
1sic3dr
Aug 11, 2008 09:52 PM
Street Ghost
Mar 11, 2003 10:30 PM
spun Vtec
25
Dec 21, 2002 05:46 AM
